Old Tiles Removed - Now What?!?! - Flooring - DIY Chatroom Home Improvement Forum
Old 10-13-2008, 09:23 AM   #1
Post
So I may have gotten in over my head. I've taken on remodelling our entire bathroom. I've removed all of the old tiles, only to find the floor is now an uneven mess of old glue and mesh material. The tiles had been laid directly down on plywood and some of the tiles actually ripped off portions of the plywood during removal I'm just not sure where to go from here.
My knowledge of flooring is very little! Is there something I'm supposed to lay down between the new tiles and the plywood? Will this take care of most of the unevenness caused by the old glue? Or should I sand the floor first? I tried sanding a small portion with a palm sander.... the glue just heated up into a mess!
Attached are two photos of my situation. You can see where the vanity used to sit, as there were no tiles there, the floor is perfectly smooth! Thanks for all your help.
Pineapple is offline   Reply With Quote
Old 10-13-2008, 12:48 PM   #2
This is a tough one.
I have no idea how deep the holes are in the plywood.
Minor ones could be covered when you put on the mortar. Deep and wide ones could be filled with leveling material that you get at your local flooring store.
To get plywood level I have used a vibrating floor sander with mild grit.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-13-2008, 12:52 PM   #3
The holes aren't too deep. Maybe halfway through at most. There is another layer of plywood underneath, so I'm not too worried about the structure, just the uneven surface.
Old 10-13-2008, 01:00 PM   #4
I wouldn't panic. This is not unusual.
Old 10-13-2008, 01:52 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Jheeeeezh! Can you get those pictures any bigger? I thought I was at an IMAX!
What you have there isn't typical but it also isn't unusual. If it were me I would cover that mess with some Self Levelling Compound and be done with it. Don't forget to use primer if you do that. Home Depot sells Level Quick for just that purpose.
Old 10-14-2008, 12:02 AM   #6
SM1
SandMasters ProFloorCare
SM1's Avatar
thinset and screw hardi backer to the subfloor then thinset tiles to that.
SM1 is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
How to remove thinset residue after old tiles removed? sz8 Flooring 11 01-01-2011 09:49 PM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 01:10 PM
