Old Tile On Concrete Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 01:38 PM   #1
Old Tile on Concrete floor
I was wondering if you could use hardibacker set in thinset over a concrete floor or wonder board.
I need to bring a concrete up to the level of the old tile as this tile will not come up from the concrete very easily I need to get the floor level to be able to cover it with carpet. I have a very limited budget to get this done and a leveling solution is to expensive for the space. Any suggestions would be greatly apprieciated.
bmenton is offline   Reply With Quote
Old 01-27-2009, 06:53 PM   #2
The cheapest solution.
Pull the trim.
Get some plastic sheeting and tarp off the doorways leading out of the area where the old tile is.
Get a sledgehammer and beat the crap out of the tile. Wear jeans... did it in shorts once and had bits of ceramic stuck in my shins.
Sweep and shovel the debris out.
Any bits here and there that got missed... hit 'em again.
Up close to the walls and in corners, where swinging a sledge is dicey... hammer and chisel time.
Mudd is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
Tile on concrete floor....with 1/8th inch cracks.. tigerbalm2424 Flooring 23 06-21-2008 09:01 PM
Join Wood Cyc Ramp to Concrete Floor Bigboots Building & Construction 3 11-27-2007 09:52 PM
