-   -   old termite damaged hardwood (http://www.diychatroom.com/f5/old-termite-damaged-hardwood-8030/)
Kbotard 04-26-2007 11:29 AM
I moved this thread to over here hoping for some help.
:thumbsup:
Hi. My husband and I are renovating my old home. We discovered ancient termite damage in the living room. I say ancient because when removing the vinyl tile and subfloor, we were inundated with red dust. Anyway, the hardwood floor is not salvagible in the living room, but the 2 bedrooms and hallway are perfect. They had used what looked like roofing paper on the hardwood, then the 1/4 inch subfloor, then the vinyl. What I want to know is, that since the existing good hardwood has no subfloor, when I replace the living room floor, can I put down the hardwood floor without a subfloor? I don't want a height difference in the rooms.
AtlanticWBConst. 04-26-2007 05:14 PM
:thumbsup:
Hi,
Question, What is on the floor now (On top of the joists?)
Kbotard 04-27-2007 09:42 PM
ON top of the joists
Just the termite damaged hardwood is on the joists. I believe it is pine. There is a small area that has no damage. I plan on saving that and using it for replacing a small corner of damage (water, not termite damage) in one of the bedrooms. So should I put down a subfloor in the living room, or can I lay the hardwood directly on the joist like the original hardwood from the late 40's?
AtlanticWBConst. 04-28-2007 04:30 AM
Hardwood should be installed on a subfloor.
If you are determined to have hardwood flooring there, you are just going to have to live with the minor step up.
Use a wide transitional molding to make it a little more discrete.
AtlanticWBConst. 04-28-2007 04:48 AM
Here is some additional information regarding subfloors:
Links:
http://www.hardwoodinstaller.com/har.../subfloors.htm
http://www.hoskinghardwood.com/all-a...-subfloors.asp
Ron6519 04-29-2007 11:42 AM
Put down a subfloor. Without it you will generate a large amount of waste with the flooring. The flooring will need to be cut so it lands on a joist and you will lose the t/g off the ends. The flooring you get now has very few long boards compared to the original floor.
Ron
Kbotard 05-14-2007 01:58 PM
What is t/g?
AtlanticWBConst. 05-14-2007 02:03 PM
What is t/g?
Tongue 'and' Groove.
AtlanticWBConst. 05-14-2007 02:22 PM
BTW - Here are a couple of pictures of hardwood flooring transitions with different thickness flooring:
http://i28.photobucket.com/albums/c2...T/IMG_1535.jpg
http://i28.photobucket.com/albums/c2...T/IMG_1539.jpg
