Old Subfloor Needs Repair - Flooring - DIY Chatroom Home Improvement Forum
Old 04-08-2008, 02:21 PM   #1
Old subfloor needs repair
I just bought an old house, 120 years old... I've pulled up the carpet because I intend to put an engineered floating hardwood floor down. There is a soft spot in the subfloor that has resulted from the supporting rock and concrete wall underneath falling apart. I don't have any access to this part of the floor from the basement. So my problem is that I can't screw the floor down to make it solid (if I could I would and then just build it up level), so it's basically just floating there not screwed into or supported by anything. I'm wondering if anyone has a fix for this without tearing up the floor...
Darryl
rdmccaw is offline   Reply With Quote
Old 04-08-2008, 08:53 PM   #2
Boz
Gus
Boz's Avatar
Nope, gotta cut it out.
Boz is offline   Reply With Quote
Old 04-09-2008, 07:32 AM   #3
That's what I figured, I did it last night, wasn't as hard as I thought... just set the saw to a height to only cut out the subfloor, then I removed the 1" planks underneath and just built it up using new lumber...by using the concrete supporting wall holding up the main floor I was able to make it solid as a "rock"...
Not as big of a job as I thought.
Cheers
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
LB Mower Repair Question kennykenny General DIY Discussions 1 09-23-2007 12:12 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 10:02 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 01:02 AM
