Old Sub-floor Thicker Than New Sub-floor - Flooring - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 01:49 PM   #1
Old sub-floor thicker than new sub-floor
I cut out some old tongue and groove sub-floor to install a new bathroom in my bedroom. Now that the plumbing is complete, I've cut 3/4" plywood to for the new sub-floor. Unfortunately, the old tongue and groove planks are about 1/16 to 1/8 inch thicker than the plywood I've laid down.
How can I go about matching the height of the plywood to the height of the old boards?
I've read the using a leveling compound is not ideal because it will crack when nailed/screwed into. I'm thinking I could either shim it up or put some kind of thin board on top. Once I get the sub-floor flush and level, I'll be adding 1/2" backer board over the sub-floor for tile. Any recommendations you have are appreciated. Thanks!
Old sub-floor thicker than new sub-floor-img_0970.jpg   Old sub-floor thicker than new sub-floor-img_0971.jpg   Old sub-floor thicker than new sub-floor-img_0973.jpg   Old sub-floor thicker than new sub-floor-img_0974.jpg
svarmaii is offline   Reply With Quote
Old 12-18-2010, 01:58 PM   #2
the Musigician
DangerMouse's Avatar
If it's just the edges shown, can't you chisel DOWN the old T&G to the level of the ply?
Might take a half an hour....
DM
Old 12-18-2010, 04:19 PM   #3
I guess I could do that. How could it be done in a half hour? I imagine it would take days to get through all that wood with a chisel. Maybe I can find a place that rents out a flush cut tool.
Old 12-18-2010, 04:34 PM   #4
Lay down 1/4" luan on top of the plywood to bring it up to the old subfloor's height.
ttech is offline   Reply With Quote
Old 12-18-2010, 04:35 PM   #5
the Musigician
From your pics, it only looks like a few inches around the edges, except for the triangle by the door?
Or is there more not shown?
Chisel around nails, hammer them down deeper when cleared.
See if your local BB store rents a Fein multimaster type tool? That'd go quicker, I imagine.
DM
Old 12-18-2010, 04:36 PM   #6
the Musigician
He said 1/8" to 1/16"... that'd just cause the same problem in reverse!
DM
Old 12-18-2010, 04:40 PM   #7
Civil Engineer
Rewards Points: 4,580
You can use 1/8 inch thick plywood, glued down. Works fine. You can sand the joint between the T&G and the plywood to make it perfect. Once you place the backerboard over the floor, no one will ever know, and I am not talking. Alternatively, you can skip the backerboard and use straight thinset, assuming the floor is stiff enough.
Tags
leveling problems , not flush , sub floor thickness
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
