Old 03-01-2013, 07:51 PM   #1
Old pine floor with ringshank nails
I've got an old T&G pine floor that someone years ago decided to drive a bunch of ring shank nails and finish nails through to try to quiet. Then they put down carpet over it. I hated the carpet so I ripped it up and the pine is beautiful except it needs refinishing. The finish nails I can drive further in with a nail set but I'm worried they'll pop up again over time and ruin any new poly I put down after sanding. I don't know how I can sand with the heads of the ring shank nails exposed. How do you guys deal with this when you see it? I hate to cover with a new floor.
TIA
eclark is offline   Reply With Quote
Old 03-01-2013, 09:29 PM   #2
MarginallyQualified
cats paw.
call the resulting divots "patina"
Old 03-01-2013, 09:57 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... Back when I did this floor, I just sunk the nails with a hammer, 'n caulked the cracks, 'n Sanded it...
I think the nails, 'n cracks add Character to the 100 year old boards...
Old 03-05-2013, 03:00 PM   #4
gravity always wins
If the finish nails are driven in well, I doubt they'll back out. Take a dremel tool and grind the heads off of the ring nails. Then sink them in like finish nails.
Old 03-05-2013, 03:14 PM   #5
Super Moderator
Take extra caution when sanding---often the sparks from the sander will ignite the sawdust----
So always empty the bag into a metal can well away from your house---each time you stop sanding.
Every floor guy I know has a smoking sanding bag story----don't join the group----
oh'mike is online now   Reply With Quote
Old 03-06-2013, 08:01 AM   #6
Thanks guys. Interesting idea to grind the heads off with a dremel. I'll call that my backup for where the nail heads don't have enough lip to grab with the cars paw. This is going to be way more labor than I was thinking.
Old 03-06-2013, 08:10 AM   #7
Super Moderator
Fixing someone elses lousy patch job is always more work---
You will be thinking about how easy it would have been to do it right the first time----
Old 03-06-2013, 08:31 AM   #8
That's the story of my house. Fortunately most of what someone boogered up is aesthetic. No major structural issues found yet...
Old 03-06-2013, 08:40 AM   #9
Super Moderator
I helped a homeowner save a bad pine floor----man, that looked gorgeous when it was done----
That floor was so black,worn and just plane ugly before we started-----
After sanding---I applied two coats of wipe on poly----lightly sanded with fine paper--then three coats of brush on poly----sanded lightly after the second coat----
Looks great----they wanted new hardwood but the budget was not there---now they are glad they save the beautiful old stuff-----
Me ranting about nails... Pittsville Building & Construction 14 10-05-2012 01:26 PM
Cleat nails for old pine floorboards? Brigante Flooring 1 07-19-2012 09:55 AM
33º vs 35º Nails Dilemma banzaitoyota Tools 1 12-28-2010 07:44 AM
nail guns & nails koodawg Tools 4 12-06-2010 11:05 PM
