Old Padding On Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 01:28 PM   #1
old padding on hardwood floors
I have carpet padding that been down for 20 or more years. How do I remove it without damaging the floor.
betty2 is offline   Reply With Quote
Old 12-10-2010, 02:57 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 114
What kind of pad, horseshair, foam, bubble rubber, rebond etc.?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-22-2011, 07:14 PM   #3
Need Expert Advise for Glued Carpet over Hardwood Flooring
I am going to try and remove rubber backed glued carpet from hardwood floors. Is there a method that someone could recommend.
kiteboarder is offline   Reply With Quote
Old 04-22-2011, 07:46 PM   #4
Rewards Points: 114
Only way I know is to hand scrape and then sand the floor. You might be able to rent a machine, but they aren't common anymore.
Old 04-22-2011, 09:59 PM   #5
Machine Rusty?
Okay, I thought I would have to hand scrape, but you mention a machine that may not be around anymore...what machine is that? What use?
Old 04-22-2011, 10:39 PM   #6
Rewards Points: 114
Back when there was a lot of rubberback carpet being installed, maybe 20 years ago, most stores had a machine that would scrape up the rubberback. I would check with some local flooring stores about renting one. With one of those, you could take it up in a large room in a couple hours. You would still need to sand but there would be very little hand scraping. I have taken up thousands of yards with one and anyone can run one.
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 11:20 AM
Old Glue on Original Hardwood Floors! gh4444 Flooring 5 02-11-2012 12:13 PM
New buckled hardwood floors Angela3511 Flooring 12 07-16-2009 07:58 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
