Old To New Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 06:18 PM   #1
old to new laminate
Report Post Today, 06:12 PM
A plumbing leaked ruined 1/3 of our Harmonics brand(Costco) laminate floor. At the time of installation, the planks required a separate padding to be installed before the laminate planks. The NEW Harmonics that is compatible comes with the padding already attached to each plank. There is a height difference in the old and the new that I can overcome if I can remove the pre-attached padding from the new flooring, then use the old style padding. My question is: Can the pre-attached padding on the plank be removed reasonably easily? Thanks.
dinobas is offline   Reply With Quote
Old 02-26-2011, 09:53 AM   #2
Pro Newbie, Thank You!
Pad Removal
The pad can be removed with a razor scraper. I have had to do that before myself. You can find a 4" razor scraper at your local home center for about $15. They'd be in the flooring and paint departments.
If you take a utility knife and cut the pad lengthwise with the laminate (into thirds), it will scrape off easier.
Broadhurst is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
New Laminate Floor Installation Creaks.... c3uo Flooring 13 07-12-2011 01:43 PM
Can't decide: Laminate or Engineered? rogersmj Flooring 7 08-30-2009 09:10 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
