Old House With Paper And Fabric Over Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 12:10 PM   #1
Old house with paper and fabric over subfloor
I pulled up my living room carpet to find out that there is an unusual material underneath the pad. It is some sort of weave that appears to be glued to the subfloor with newspaper overlayed. We have removed everything we could, but most will not come up and it seems to be holding moisture (particularly with the high humidity). Anyone have any ideas how to remove?
twityk is offline   Reply With Quote
Old 08-01-2011, 12:15 PM   #2
Rewards Points: 150
Ground floor or second floor? Does it look like landscape fabric?
Broughton is offline   Reply With Quote
Old 08-09-2011, 03:28 PM   #3
Old House Flooring
This is thre main floor, but there is a basement.
I suppose it could be landscaping fabric. It is green in color and has a heavy weave. The Newspapers date back to 1980.
Old 08-09-2011, 03:51 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What happens when/if you wet it and let it soak a while? Will that soften it?
XXX
Old 08-09-2011, 04:00 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
I would take a guess that the fabric is part of some old carpet pad. Some of the bubble rubber pad(which was actually made from clay) had a fabric type backing which stuck to the floor almost like being glued. There is no easy way to get it up. Don't know why newspaper was put over it, but after 40 years in this business, nothing surprises me.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-10-2011, 11:00 AM   #6
When wet/damp, it seems to just absorb and stink. newspaper will soften, but the material doesn't.
Old 08-10-2011, 11:20 AM   #7
Rewards Points: 148
The only way I know to remove it is to scrape it. And then, if needed, sand off the residue.
Old 08-10-2011, 11:22 AM   #8
Rewards Points: 148
What are you planning on installing over it? And is this concrete or wood subfloor?
Old 08-11-2011, 02:20 PM   #9
We were leaning toward carpet. That's why my concern. If it continues to draw moisture, it will reuin any new carpeting placed down.
Old 08-11-2011, 02:25 PM   #10
Sounds like something I recently ran into....
In my situation, it was part of the old carpeting/padding. Seems the floor had been re-carpeted before, and the previous carpeting/padding had not been removed entirely/properly (and when I wet it, to try and help remove it - it absorbed the water and STUNK too).
Just a thought.
Earl Williams is offline   Reply With Quote
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
