Old House Bathroom Replacing/sistering Joists - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 05:05 PM   #1
I have a small bathroom (92x74) I recently gutted. (I have attached pictures) I pulled up the sub floor revealing 3 joists. They are notched into beams running perpendicular and they are 27" apart on center and each joist measures 4x3 (actual measurement). Under each joist there looks to be a second piece of wood that I assume is simply to connect the ceiling below and offers no structural support. One of the joists (the one near the toilet pipe) at some point rotted out and was "fixed" by some 2x3's around the base of the toilet and those also rotted out. (in the photo is may look like the middle joist is rotted as well, but that is actually the 2x3's used around the toilet. The middle joist is before it and in good shape.)
I removed a standard cast iron tub and I am replacing it with a 60x60 corner whirlpool tub.
So my questions:
1) Can I simply replace the rotted joist completely using a similar piece of wood notched the same way? (I am pretty sure whats left of that joist I could remove simply by lifting it up)
2) Should I sister all 3 of the joists, and if so how? (I'd assume I would use the metal joist hangers to connect to the main beams?, can metal hangers be used to sister into my existing notched beam?) or should I skip sistering them and just add additional joists in between the existing ones again using metal joist hangers? My concern is can the modern metal joist holders be safely attached to old school beams since they arent perfectly flat like modern lumber? Can the metal hanger be attached close enough to sister joists?
Thanks for any replies!
Velvis is offline   Reply With Quote
Old 03-23-2012, 10:59 PM   #2
Remodeling Contractor
metal joist hangers will work fine. These are available for one, two or three joists wide. remove the bad joists if possible.
Old 03-23-2012, 11:04 PM   #3
Rewards Points: 14,010
The joist you have now are way to far apart, Add one between each one.
Old 03-23-2012, 11:10 PM   #4
yes agreed.... I missed that 16" OC.... flooring should be 12" OC
Old 03-24-2012, 12:39 AM   #5
Ok, thanks for the tips.
Do you think replacing the damaged joist and placing two new joists between the existing 3 will be enough?
Or should I put two new joists between each existing joist?
There isnt enough room to put new joists on the outside of the number 1 and number 3 joists.
Also what type of wood should I use for the new joists?
Old 03-24-2012, 06:27 AM   #6
Kiln dried doug fir
no need to sister them 2X10 are enough
Old 03-24-2012, 01:54 PM   #7
I dont have the height for 2x10s. What about doubled 2x6s?
If doubled 2x6s are acceptable should I glue and screw them together first when using a double joist hanger?
To be clear the 2x6s would be in addition to the 3 existing 4x3 joists that are 27" O.C.
Also I need to replace the rotted joist that measures 4x3. Home Depot didn't have anything that size (They had something close but it was treated wood and rounded on the top and bottom), is there a place to purchase a replacement beam that measures 4x3? It needs to be that size to fit into the existing notches on the cross beams.
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Old House Bathroom upgrade KBS Flooring 13 11-14-2011 12:01 PM
Bathroom in the pool house kybenz Plumbing 2 05-11-2011 04:52 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
new bathroom old house pigman Building & Construction 2 08-28-2008 07:45 PM
