Old 03-19-2011, 01:41 PM   #1
Talking
Old glue ok for New Linoleum?
Ripped out old linoleum. Old glue gets gooey with water application, which Im told means it is water based and tile can't be placed over it. Don't have time to remove all the old glue. If i put more linoleum down, do I have to remove all the old glue or can I just put a similar glue over the old stuff? 50 year old slab level, good condition.
toastercombo is offline   Reply With Quote
Old 03-19-2011, 01:45 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Vinyl adhesives have changed a lot thru the years. It may not be compatible, besides you probably won't end up with a smooth floor.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
carpet glue pfmartin0387 Flooring 1 10-03-2010 09:17 PM
linoleum over old carpet glue my4angels Flooring 3 09-04-2010 06:21 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 08:11 PM
Can you run laminate over old linoleum glue? Player Flooring 13 06-23-2010 04:16 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
