OIS Bimetal Blades - Flooring - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 06:50 PM   #1
OIS Bimetal blades
Will an OIS Bimetal blade be tough enough to cut off deck screws?I need to remove deck boards but cannot get access to the heads since they were completly covered during a remodel. A Reciprocating Saw would probably due too much damage. An OIS tool would be the best bet if I can find a blade tough enough.
Terry2 is offline   Reply With Quote
Old 04-03-2012, 06:23 AM   #2
Rewards Points: 1,766
I think you'll go through a fair number of blades; depends on how many screws you have to cut.
I'd use the recip from underneath if access allows. Not sure what damage you'd do then?
bob22 is offline   Reply With Quote
Old 04-06-2012, 08:35 AM   #3
Research looks like you are right, seems deck screws are toughest to cut; however, since the screws are less than 3/4" from the newly installed vinyl flooring inside new addition, I think it will be the way i will be going. There is an American company named Imperial that makes a Titanium blade for ois that looks promising.
I only have about a half dozen screws to cut.
If I mess up new addition, the spouse will have me in the doghouse!
Thanks for your reply.
Old 04-06-2012, 10:32 AM   #4
Good luck with it; post an update when you're done.
How to resharpen carbide paint scraper blades?? RickDel General DIY Discussions 1 03-24-2012 10:53 AM
Ridgid Saw blades kevsprojects Tools 12 03-17-2012 07:16 AM
Need Help Replacing Spiral Blades on Snow Thrower cynergyou General DIY Discussions 3 01-22-2011 08:53 AM
Sears 536.884351 auger blades are discontinued, no replacement MichaelLit General DIY Discussions 2 07-08-2009 06:43 AM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
