Oil Or Water Based Polly? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-13-2008, 10:57 AM   #1
Oil or Water based Polly?
I am thinking about re-finishing my floors myself, but wanted some guidance regarding Polly.
I have read a little regarding Oil vs Water based, but wanted opinions what works best, and holds up the best as well.
I have a fairly new home with hardwood that was finished by the builder. he didnt do all that great of a job, and the poly is actually peeling and flaking at the bottom of our stairs.
Should I go with Water or Oil? Any name brands i should use, or stay away from?
Is a belt sander the way to go, or can i use the random 3 pad style sander that Lowes rents out. (Varathane)
What Grit should i start out with, and then finish with? (Foors are in ok shape).
how many coats of polly should u put down, and in between coats of polly, do you re-sand, and if so do you do it by hand?
David_D is offline   Reply With Quote
Old 10-13-2008, 01:57 PM   #2
Rewards Points: 83
Major differences:
Water based: clear finish (no yellowing which may/may not be desirable), easy clean up, faster drying, requires more coats for the same level of finish as oil based, more expensive.
Oil: Slow drying, yellows, fewer coats, cheaper, harder clean up, stinks.
In my experience Oil based is much easier to apply as the way it flows it levels easier.
However:
IMO, this is a losing battle as far as ROI. Hire a pro and get it over with. I believe in DIY, but I also know limitations.
Bubbagump is offline   Reply With Quote
oil vs water poly batwoman Flooring 6 09-30-2008 11:00 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Sanding in between Varathane water based floor finish? Joony Flooring 1 07-09-2008 08:10 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
