Oh, No. I Dropped Lime-away On My Marble Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 06:55 AM   #1
Rewards Points: 87
oh, no. I dropped lime-away on my marble floor
Hello all:
Recently when I was cleaning my toilet w/ lime-away, I splattered it on my marble floor. I didn't discover it until days later. Now it seems the droplets have stained the marble floor. I have used 2 different sealers trying to get it up with no luck.
Any suggestions?
momof2labs is offline   Reply With Quote
Old 04-05-2013, 07:34 AM   #2
Rewards Points: 13,450
Marble is a very poris tile.
Not sure why you would be trying to use a sealer to remove a stain.
Your just sealing the stain into the tile.
May be to late now to get the stain out.
You were using an acid to clean with so it should have been nutralized with something like baking soda then sucked up with a shop vac or at least blotted up.
Old 04-06-2013, 06:06 AM   #3
Rewards Points: 87
Great minds think alike!
Dear JoeCaption:
I was thinking of using the Dremel with a soft head with soda thinking more that it would polish the marble. Great advice. Thanks.
Old 04-06-2013, 06:26 AM   #4
DIY staff
Rewards Points: 7,174
You may need to polish the marble---------marble dissolves when touched with an acid---
So the surface is now damaged.
There are polishing kits available----do a Google search-------
momof2labs (04-15-2013)
Old 04-06-2013, 07:40 AM   #5
Got a picture?
Old 04-06-2013, 08:54 AM   #6
Rewards Points: 258
How may tiles are affected? Do you have or can you purchase replacements? You may not be able to polish out the stain but it is worth the try.
Limeaway contains hydrochloric acid (HCl) and likely there was a chemical reaction (not good news) when it came in contact with the marble. It would not hurt to call the manufacturer at 1 800 228 4722. All of the big compaies that make products similar to this one have chemists on hand. Maybe one can steer you in the right direction. In any case the sealer needs to be removed. Good luck.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 04-06-2013, 09:44 AM   #7
ccarlisle's Avatar
It is not a 'stain'; it's an 'etch'...
Only remedy = polishing it out.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 04-06-2013, 10:41 AM   #8
Rewards Points: 258
I figured it was an etch but the OP called it a stain. It will be very difficult to grind or buff out an etch and still be happy with the results. A stain would have been easier to deal with. The OP should run his/her finger over the surface and confirm that it is no longer smooth. This will confirm an etch.
Old 04-15-2013, 03:58 PM   #9
Rewards Points: 87
Hi Retired Guy 60: It is an etch! I learned something new. Since I moved I haven't found my dremel. I will follow up with the manufacturer. Excellent advice. Thanks!
Old 04-15-2013, 08:58 PM   #10
Rewards Points: 258
momof2labs,
I am sorry to say that a dremel will not remove the etch. And since it is an etch, the manufacturer of Limeaway will not be able to provide any useful info. You will need to polish out the etch and even then I don't know if you will be satisfied with the results. My first thought is to try a random orbit sander. When all is said and done, you might decide that replacing the damaged marble is the best (though most difficult to accomplish ) solution. Unfortunately accidents like this happen. I am certain the guys who post here could tell you stories of bloopers that occured at the hands of seasoned pros that ended up being costly and time consuming to repair. As they say, stuff happens.
The Following User Says Thank You to retired guy 60 For This Useful Post:
oh'mike (04-15-2013)
Tags
lime-away , stained marble floor
Fixing sealer on polished marble floor tile fatalvipe Flooring 1 01-22-2011 02:00 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Noise, hollow, movement on cultured marble floor...need help? handfix2008 General DIY Discussions 8 11-04-2008 08:25 PM
Marble Floor - Good and Bad Help dcd22 Flooring 6 07-17-2007 12:07 AM
existing marble floor installation Fog80 Flooring 5 04-28-2007 07:45 PM
