Odd Shaped Room - Flooring - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 08:50 PM   #1
Odd Shaped Room
Hi there.
I am in need of help. I am trying to figure out how to lay flooring in an odd shaped room. I get the easy part-- that I should lay the flooring in Hallway 2 into the MBR along the length on the hallway, but I am stuck with what to do in Hallway 1 and the closet.
Should I continue the line from H2 and the MBR into the closet, even though the closet would be at an angle ? OR do I lay it lengthwise and then use a transition piece.
In Hallway 1, if i run the length of the halllway, do I then transition into H2?
There would be too many transitions occuring at basically the same point and I worry that it would look odd.
Any help or advice would be appreciated. If I get this wrong the wife will never let me forget it.
Picture attached.
Noob20817 is offline   Reply With Quote
Old 07-05-2013, 11:13 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
What kind of flooring?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-05-2013, 11:23 PM   #3
I was thinking of using an engineered maple. Floating.
But if you tell me different, I'll listen
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Need a foundation in my laundry room sweetfarm Building & Construction 14 09-06-2012 09:49 PM
Choosing a Color Scheme For Your Room Micheal11 Interior Decorating 0 08-10-2012 10:03 PM
Assessing value of layout changes mbianco General DIY Discussions 6 07-21-2012 11:48 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 01:41 PM
