-   -   Odd Shaped Room (http://www.diychatroom.com/f5/odd-shaped-room-183121/)
Noob20817 07-05-2013 09:50 PM
Odd Shaped Room
1 Attachment(s)
Hi there.
I am in need of help. I am trying to figure out how to lay flooring in an odd shaped room. I get the easy part-- that I should lay the flooring in Hallway 2 into the MBR along the length on the hallway, but I am stuck with what to do in Hallway 1 and the closet.
Should I continue the line from H2 and the MBR into the closet, even though the closet would be at an angle ? OR do I lay it lengthwise and then use a transition piece.
In Hallway 1, if i run the length of the halllway, do I then transition into H2?
There would be too many transitions occuring at basically the same point and I worry that it would look odd.
Any help or advice would be appreciated. If I get this wrong the wife will never let me forget it. :eek:
Picture attached.
rusty baker 07-06-2013 12:13 AM
What kind of flooring?
Noob20817 07-06-2013 12:23 AM
I was thinking of using an engineered maple. Floating.
But if you tell me different, I'll listen
