Old 10-17-2010, 05:01 PM   #1
Oak hardwood Flooring
I am re-staining my kitchen and dining rooom. My friend applied the oil wood stain with foam brushes. I completed my sections with a white china bristle paintbrush and used a clean cloth to remove any excess stain. The result of each of us using different techniques is that the stain is uneven. Also some of the areas in which the foam brush was used is still sticky (too much stain?). Are there any tricks for evening out the color before applying a second coat of stain?
nelsonproperty is offline   Reply With Quote
Old 10-18-2010, 07:51 PM   #2
This won't answer your question but might be useful for future reference. There is a prestain sealer that is applied prior to staining wood that results in a more even appearance. You can find it in the same aisle of your home center where the stains are kept. Unfortunately since you already applied stain it is too late to use it on this project.
retired guy 60 is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 09:37 AM
Hardwood Flooring transition msfmatt Flooring 2 05-21-2009 08:57 AM
DYI Project - Hardwood Flooring Install in Hall and Bedrooms godmaster Flooring 9 04-26-2009 10:22 PM
Adding a partition wall to a room with hardwood flooring Badfish740 Remodeling 4 12-29-2008 08:54 AM
