NY Bluestone Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 05-02-2009, 08:58 AM   #1
NY Bluestone flooring
I am in a green building class and we are building a straw bale shed (for garden tools). I am looking to use NY Bluestone and either crushed stone or stone dust instead of a mortar mix. We will not be using a cement slab for the floor so I was wondering what the best way to do the flooring would be. Do I need a wire and felt paper moisture barrier under the crushed stone or above the stone layer that the rocks would be on? I want the project to be as green as possible so do not want to use cement or anything like that but do want to make it long lasting without moisture problems or major shifting problems. I would like to know the best method for laying the crushed stone and bluestone over the packed dirt ground. The project is in NY. Thanks!
punkin78 is offline   Reply With Quote
Old 05-02-2009, 02:05 PM   #2
i have experience in useing nature stone for the ground.my house is using it for the ground now.i give you an picture to have a look. anything you need is sandand slate to make it,that's very easy.you'll get the best way to hold the quantily of heat and save energy.cause the slate is nature. sorry about my poor english .cause i'm still in learning english now.
silence xu is offline   Reply With Quote
Old 05-02-2009, 02:14 PM   #3
What was the process you used with the sand, water and slate? Did you put a waterproof membrane of any kind under it?
Old 05-02-2009, 02:25 PM   #4
no not need anything sand and slate is enough. water is used to make the sand unknit ,upstair the sand is the slate.that's the way i make it.when the water becoming to the wapour ,the sand is becoming hard to . sorry about my poor english. wish you could understand what i have said.
Old 05-02-2009, 02:30 PM   #5
so the sand and water was used for the foundation and for your mortar/grout? The shed we are using does not have a cement foundation- just dirt so I was trying to find out if I need to use any waterproof membrane under the crushed rock/sand to keep moisture from the bare ground from coming up. I appreciate you helping me with this. I think I am understanding you. I have tried to learn other languages several times and was not successful so I think it is great you are in the process of learning (I found it too hard for me and gave up!).
Old 05-02-2009, 02:48 PM   #6
the answer is no, in fact the slate and the sand are all nature,do you see the line in the picture,that's the answer.it likes use the net to get the water. the water can transpire to the air .so there is no water. but if use the cement ,there is an whole space with no break,it's hard to let the water transpire to the air. get my point?
Old 05-02-2009, 03:53 PM   #7
That is great to know! I am understanding you. Thank you. If I have any more questions I will email you. I appreciate your responses. It helped a lot.
Old 05-02-2009, 04:01 PM   #8
You are welcome punkin, i just shares the chinese experience with you .by the way ,do you use the tool MSN?
Old 05-02-2009, 07:28 PM   #9
Bluestone Flooring
No, I use AIM and Yahoo but not MSN.
Old 05-02-2009, 10:50 PM   #10
could you please kindly give your yahoo ID to me? i want to learn more english and get more information about american
Old 05-03-2009, 10:16 AM   #11
Bluestone Flooring
My yahoo messenger ID is hatebreed454
Tags
bluestone , floor , green , moisture barrier
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
