Not Sure What To Do, Need Help Removing A Stripper... - Flooring - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 07:35 PM   #1
Exclamation
Not sure what to do, need help removing a stripper...
My husband recently used a paint stripper on a concrete floor, to attempt to remove what looked like vinyl tile glue, and floor paint. I need to know what I can use to get the stripper up and still be able to put new peel and stick tile down. Please help He has already removed the glue and stuff, I need to know what I can use that will take off the stripper used, and to ensure that the new peel and stick tile will stick.
M&M Wallace is offline   Reply With Quote
Old 05-25-2009, 07:45 PM   #2
lowes or home depot have some stuff you can use. I cannot recall name but i used it to remove vinyl glue. Some sort of adhesive remover. (gallon size) in a metal tin. It's thick, burns your eyes and nose be ready. I also got a straight edge scraper with a handle. It's a PITA
Ineedhelp2009 is offline   Reply With Quote
Old 05-25-2009, 10:17 PM   #3
Once you do get the stripper removed, make sure to get a bonding primer(sold at Lowes) and paint the floor with it. What was the reason for using the stripper? A razor scraper would have been better for the application.
floortrends is offline   Reply With Quote
Old 05-26-2009, 08:27 AM   #4
I never want 'em to leave ...
Oswald is offline   Reply With Quote
Old 05-26-2009, 01:38 PM   #5
I was gonna offer to help.
purplewg is offline   Reply With Quote
Removing Laminate Backsplash??? mjkpainting Remodeling 13 06-22-2009 11:58 AM
prep walls after removing paper ponch37300 Painting 1 01-10-2009 10:54 AM
Removing Gas valve/pilot control Fuzzybunny HVAC 22 12-14-2008 07:24 PM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 05:51 AM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
