Non Square Slate Tile Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2010, 03:41 PM   #1
Knows everything but that
Rewards Points: 150
Non square slate tile flooring
Hello. The wife and I are looking into putting in slate tile flooring in our bathroom. However, we dont want the traditional 12x12 or like sizes. Were looking to do something like Ive seen on peoples outdoor porches. The tiles are all uneven/unfinished however this would be on an indoor surface so the bottoms would have to be flat so I can place them with the thinset/mortar. Does such a thing exist?
Shane
JakAHearts is offline   Reply With Quote
Old 04-21-2010, 03:57 PM   #2
the Musigician
DangerMouse's Avatar
I'm sure you can do it. It sounds like a great idea to me!
You're in the right place to find out how to do it too.... Po)
DM
Old 04-22-2010, 12:17 PM   #3
jlhaslip's Avatar
Rewards Points: 1,010
buy the 12" slates and cut them to suit your layout.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 04-22-2010, 01:24 PM   #4
Rewards Points: 150
I was thinking about buying the flat ones and then just breaking them and using the pieces. Has anyone ever tried that or heard of this?
Shane
Old 04-22-2010, 01:33 PM   #5
Hi JakAHearts,
I own a flooring store and sell slate all the time, and yes we do all kinds of random patterns.
The slate we sell is available in sizes ranging from as small as 4" x 4" to as large as 24" by 24" with various sizes in between. In fact, there are some mesh mounted patterns available so you don't have to lay anything out.
As far as the actual slate is concerned, the back is generally smooth with all the texture being on top. Although you can also buy gauged slate which is means the tile thickness won't vary nearly as much from tile to tile.
I would suggest you visit a specialty flooring store or tile store (not box stores,) to find these items as they aren't a rare item.
Good luck in your search.
rcuerrier is offline   Reply With Quote
The Following User Says Thank You to rcuerrier For This Useful Post:
JakAHearts (04-22-2010)
Old 04-22-2010, 02:09 PM   #6
Shane
Hi Shane,
The issue, or potential issue, with doing that is sharp edges. Slate is naturally "layered" and if you break the tiles up you may end up with a floor that won't be so nice under foot.
I'm not sure how familiar you are with slate, but keep in mind that it is a porous stone and that it will be necessary to seal it before grouting. Also, keep in mind that the sealer is an impregnating sealer and while it may leave a slight shine (which will fade over time) it doesn't act to hold the stone or layers together. The sealer basically helps to prevent staining.
Hope that helps!
Old 04-22-2010, 03:44 PM   #7
Originally Posted by rcuerrier View Post
Hi JakAHearts,
totally agree with this. the 12x12 lowes and depot have is not flat on one side which makes an even install that much harder. they do have a gauged 16x16 available but it's costly at nearly $4/sq
racebum is offline   Reply With Quote
The Following User Says Thank You to racebum For This Useful Post:
rcuerrier (04-22-2010)
Tile Flooring Problem jogan Tiling, ceramics, marble 13 01-21-2010 08:20 PM
Tile over Tile over Slate - can slate be salvaged? jwilds1 Flooring 0 11-17-2009 04:27 PM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 08:34 PM
Carpet and slate tile on same basement floor CBH Flooring 14 06-12-2008 04:14 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
