-   -   Non cement based floor leveler /patch (http://www.diychatroom.com/f5/non-cement-based-floor-leveler-patch-33060/)
troyce1 12-02-2008 11:03 PM
Is there a non cement based floor leveler/patch?
I want to level, smooth and patch some spots on a subfloor before I put carpet down, but I am afraid the cement will be heavy and/or crack.
JazMan 12-03-2008 12:10 AM
For under carpeting a non Portland cement patch would be fine, just be sure whatever you use is made for wood subfloors. You might have to mix the powder with an additive. There are many out there.
Jaz
troyce1 12-03-2008 01:00 AM
Jaz, my question was more along the lines of can someone reccommend one?
I havent seen one at lowes or homedepot. If anyone has a link please provide it.
yesitsconcrete 12-03-2008 08:20 AM
if you need to support the apron store, look in the tile section next to the hardibacker/wonderboard stacks.
troyce1 12-03-2008 01:35 PM
I did look there, everything was portland cement based that I saw.
Bud Cline 12-03-2008 02:08 PM
It has been proven over the yrears that Portland cement based patching products are more durable and more reliable (in most cases) than any of the others. I don't understand the insistance on a non-cement material. The issue of weight is a moot point in this case.
Home centers carry several of the products in either form, you can make your own selection.:)
JazMan 12-03-2008 02:41 PM
It's very simple. You go to the hardware store and read a few boxes or bags that are labeled "patching stuff" or whatever. We don't know where you are. We don't know what brands you have a choice of. There must be hundreds of possible choices?
I have no idea why weight popped into your head. Hopefully you're only repairing a small area that is maybe the thickness of one ply? Almost anything that sticks to wood will work under carpeting.
Jaz
poppameth 12-03-2008 06:16 PM
I just poured 800 lbs. of cement based self leveler on an upstairs wooden subfloor for radiant heat. Not a bit of problem with it. Go to Lowes and get the Laticrete 86 kits (rated for use on ext. grade plywood) and stop worrying so much about the weight. Worry more about the quality of the work you have to live with.
ClaudeBallz 07-08-2012 09:18 AM
This fellow asked a legitimate question...but
I know...this is a reply to a very old post, but I think someone needs to step in and give an alternative.
The guy asked a simple question about alternatives to a cementitious floor leveler. None of you gave him an alternative. :eek:
For small areas which need to be filled, some have used Bondo or another type of automotive patch. But it's expensive for even small areas, let alone what it would take to fill a very large area. They used it because they were putting a nail down floor of bamboo. One CANNOT use a cementitious compound such a case. Oh yes, there will be some knothead who will say you can use it, but there are always people who speak out of their back door and build crappy construction routinely. :furious:
rusty baker 07-08-2012 10:35 AM
Every store has it's own brand of gypsum based floor filler. But without knowing where this peson lives or shops, it's impossible to give them a brand name. I wouldn't use it even under carpet. It tends to break up over time.
