Noise Abatement Underlay - Flooring - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 06:40 PM   #1
I live in an apartment that unfortunately has the typical problem of being able to hear every single footstep from the neighbors upstairs. I recently found out that these neighbors are going to be moving and they are going to renovate the entire apartment. I was going to ask them if they could lay an overlay in between the subflooring and the new hardwood and carpet to help alleviate the foot traffic noise. I was wondering if anyone has used any good noise abatement products to great success? I found the simplesolutions underlays on Home Depot, and wondered if anyone has used those and what they would rate them? Or if there is another product out there that gets the job done.
Thanks!
lukeshow is offline   Reply With Quote
Old 12-04-2010, 09:35 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I'd use cork sheeting underlayment. But that is an expense they probably aren't willing to put into the place. Any sound reduction underlayment may be additional cost they don't want. Keep that in mind before you ask. It is their money you are asking them to spend o a place they aren't even going to be living in.
poppameth is offline   Reply With Quote
Old 12-04-2010, 02:32 PM   #3
thanks poppameth,
yeah, i think cork is way too expensive, but i'm actually willing to put up the money myself if it means saving a little bit of sanity. the simplesolutions soundbloc foam is fairly inexpensive and i was hoping to get someone that has used it or something similiar to chime in and see if it is actually worth me putting money into it, or if I just have to grin and bear it.
Old 12-04-2010, 03:46 PM   #4
C W
noise from above
Thanks!
Quiet Floor is a foam insulator and sound proofing product that is installed under wood floors ,for carpet a realy good 10lb underlay is all that is needed
C W is offline   Reply With Quote
Tags
noise floor squeaky
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 09:05 AM
Frigidaire freezer noise (sounds like a compressor) onelove Appliances 3 10-09-2010 09:16 AM
Flat roof rafters noise mtrx Roofing/Siding 5 03-09-2010 10:16 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 11:25 AM
