No-glue Vinyl Sheet Over Ceramic Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 12:41 PM   #1
no-glue vinyl sheet over ceramic tile
My bathroom floor is only about 5'X10' and currently 10'' square ceramic tiles in very good physical condition. I want to re-do the floor but not hassle with removing these tiles and underlayment. As long as I fill in/smooth over the grout joints, is there any reason why I can't lay down some no-glue vinyl over it? I used this stuff in my kitchen and absolutely love it. Thoughts...?
cswanson69 is offline   Reply With Quote
Old 08-03-2012, 04:07 PM   #2
Rewards Points: 14,026
I would never use it in a bathroom but it will work until the water ends up getting in under it and causing mold.
I would use glued down and seal the outer edges with silicone before the trim went in.
cswanson69 (08-03-2012)
Old 08-03-2012, 04:23 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
You have to cut the vinyl 1/4" short of the walls anyway, so fill that with flexible caulk. Then put 1/4 round trim over it, nailed to the wall. It will work fine.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Old 08-03-2012, 07:33 PM   #4
Thanks guys.
how do I attach ceramic tile to ceramic tile? porchhen9 Remodeling 8 07-31-2011 02:59 PM
Can I lay ceramic tile on a pier and beam with Vinyl? sandy 74 Tiling, ceramics, marble 1 02-17-2011 09:51 PM
no glue vinyl sheet flooring cswanson69 Flooring 2 10-12-2010 10:50 AM
Tile over sheet vinyl? jonathan03 Flooring 1 07-06-2010 05:36 AM
Installing Ceramic tile: Ditra over Vinyl or rip out and use 5/8 Plywood? ppieda Flooring 2 10-05-2007 11:01 AM
