Old 04-20-2007, 09:15 PM   #1
no glue vinyl floor (armstrong)
I am considering using 'no glue' vinyl floor in the kitchen. Has anyone had any experience with this? Its new to me and seems too good to be true - can lay over existing vinyl floor and no glue! I would appreciate any pros/cons anyone may have. Thanks.
kirtland is offline   Reply With Quote
Old 04-21-2007, 03:37 PM   #2
"no glue" vinyl installations are not new they're just a cheaper ? way of placing a vinyl floor over an existing one. Years ago we did many in apartments where the tenant did not care for the "look" that was the kitchen floor but landlord either refused to redo or did not allow the tenant to place a new gluedown floor over the old, so we would loose lay a new vinyl over the old. My opinion is that it is a temporary floor and will not wear as well as a glued down over a properly prepared substrate.
Zero Punch is offline   Reply With Quote
Old 04-21-2007, 07:33 PM   #3
Home Improvement Guy
ron schenker's Avatar
The ones that I've installed were more fibreglass than vinyl and they wear very well. Not cheap either, around $5/sq.ft. All that is needed is to seal the edges with silicone caulk. Guaranteed not to shrink or expand. Very easy to work with as it won't buckle if you fold it. Looks pretty decent too, I love the stuff.
ron schenker is offline   Reply With Quote
Old 04-22-2007, 09:31 AM   #4
Yeah, they sd it was basically fiberglass. There is a special type of tape that you use to bond it to the floor. Armstrong also sells an install kit that guarantees a perfect install (if you miscut, they will replace the flooring (up to 26 sq yds).
Im going to get some today and install it Tuesday. Ill let you know how it goes....
Old 04-22-2007, 09:33 AM   #5
And the cost is only $1.11 a sq ft (some were only $0.88 a sq ft!) at HD
Old 04-22-2007, 02:10 PM   #6
Floorwizard's Avatar
I wouldn't say that.
But the product is a good one along with other manufacturers.
This is the Vinyl of the future so prepare for it.
Emboss level the old floor first or the pattern will come up thru the new one.
Floorwizard is offline   Reply With Quote
Old 04-22-2007, 05:25 PM   #7
There's a graveyard of the floors of the future out there. I don't have enough fingers and toes to count them all over the last 40 yrs.
Don't get me wrong I'm all for new products I'm just a bit jaded on hype.
Old 04-24-2007, 01:23 PM   #8
Young DIY
I just purchased some cork flooring from www.lumberliquidators.com, it is supposed be the next big thing... I am remodeling my bathroom with it. I just finished my bonus room with some laminate from the same company. I cannot wait to get it, I think it will look awesome!
scrtagtmn06 is offline   Reply With Quote
Old 04-30-2007, 12:14 PM   #9
So far all of my jobs have went extremely well.
your right, time will tell.
But usually after a year of using a product, I will see problems with it in that time frame that will lead me to believe this may not work out.
glueless Vinyl product NoviceDIY Flooring 7 08-20-2010 06:52 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Vinyl siding brickmold rjniles Building & Construction 1 02-05-2007 11:55 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
