New Toilet Old Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 04:51 PM   #1
Lord of Slums
Rewards Points: 1,974
New toilet old linoleum
I need a strip of linoleum about 16 inches by 6 inches. Can I cut a strip from behind the fridge? It was professionally installed 10 years ago. Looks like it is really on the floor tight. Could I possibly match something from the big box? Open to suggestions.
mj12 is offline   Reply With Quote
Old 04-09-2013, 05:09 PM   #2
Rewards Points: 744
You might be able to pull up a piece from behind the fridge. It will likely be difficult though. I doubt the big box stores or anyone else for that matter are going to have anything to match 10 yr old vinyl/lino.
Seattle2k is offline   Reply With Quote
Old 04-09-2013, 05:11 PM   #3
Rewards Points: 13,450
What are you really trying to do with that small a piece?
Old 04-09-2013, 09:27 PM   #4
Lord of Slums
Set a toilet and the base of the bowl is smaller than the old toilet. It was an old American Standard toilet from the 70's and now is a new Mansfield toilet. In the back there is a small strip where the bowl will not cover. I can get a picture next week sometime. I am guessing on the size I need exactly. Happens to the best of us
Old 04-10-2013, 07:26 AM   #5
Someone cut around the base of the toilet instead of removing the toilet and cutting around the flange!
Old 04-10-2013, 09:24 AM   #6
Rewards Points: 4,796
My first reaction would be to go with a toilet base plate to cover. Trying to patch in linoleum can be difficult, and if not gotten exactly right, the sight of it will always bug you.
jeffnc is offline   Reply With Quote
Old 04-10-2013, 11:09 AM   #7
Lord of Slums
Yeah, someone cut a corner. Too bad I could not call the guy I had do the floor and ask him why he was so cheap and lazy. I am wondering how it would look if I had to tile a 3 foot by 3 foot area of the floor and tie it into the linoleum. Quarter inch backer board, quarter inch tile would be a big bump in the floor.
Old 04-10-2013, 11:45 AM   #8
Again, a hack that will probably look weird.
Use a toilet base plate.
Or redo the floor with new linoleum. How hard can that be?
Or if you're thinking of tile, then just tile the whole floor for cryin out loud!
Old 04-10-2013, 11:53 AM   #9
Floor Installer
sam floor's Avatar
Rewards Points: 154
If it's to be temporary, use peel and stick on the whole floor. Just be aware that it won't last very long. Maybe a few months.
sam floor is offline   Reply With Quote
Mini-project: Rebuilt my toilet. First time doing it. r0ckstarr Project Showcase 6 05-13-2014 02:59 PM
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
