Old 09-19-2011, 12:54 AM   #1
New Tile in Toilet Area
My home had cultured marble in the master bathroom. I had this removed and replaced it with ceramic tile. The ceramic tile isn't nearly as thick as the cultured marble and now my toilet sits ~3/4" too high.....
How do I fix this?
JHensley is offline   Reply With Quote
Old 09-19-2011, 05:38 PM   #2
Wasn't the toilet removed before tiling? How thick was the cultured marble?
bob22 is offline   Reply With Quote
Old 09-19-2011, 05:54 PM   #3
Tileguy
Bud Cline's Avatar
Cultured marble on the floor ???
Grout the toilet with tile grout.
Old 09-19-2011, 06:01 PM   #4
AlbacoreShuffle's Avatar
Your going to have to lower the flang or you can try one of these.
http://www.sachwin.com/products/toilet_base_plates.php
AlbacoreShuffle is offline   Reply With Quote
Old 09-19-2011, 06:05 PM   #5
Tileguy
Bud Cline's Avatar
Shim the pedestal and...
Old 09-23-2011, 11:16 AM   #6
Okay, this thing turned into a ridiculous ordeal. So, thanks for all the replies.
Yes, my bathroom had cultured marble flooring. Apparently someone thought it looked good in 1985.
So, I cut the old flange off, flush with the new floor. I tried to use a 3" hole saw to bore the sleeve (about a 8" sleeve) that was attached to the old flange. My drill didn't have the balls to bore out the sleeve, so I used a flange with a 4" fitting that fit over the pipe... more to follow.
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
Resilient tile - under toilet flange? mn1247 Plumbing 2 06-23-2011 10:13 AM
Toilet pipe rises above new tile floor jmsmith251 Plumbing 2 10-24-2010 09:16 PM
What are the 'code' space requirements for a toilet in a three walled area?? 4just1don General Discussion 6 05-21-2009 10:40 PM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 09:59 PM
