New Teak Floor On Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 05:55 PM   #1
Talking
New teak floor on concrete slab
Hello,
I've recently been offered a quantity of Indonesian teak beams, which I plan to have milled into hardwood flooring. The beams are 3 in x 12 in x 12 ft.
How would you recommend I have these beams cut, to make a fair balance of economy of materials and fantastic final product? Is there any advantage to having a hardwood floor thicker than 0.7 inches? Should I absolutely have is t&g'd?
Part of this will be installed over a newly poured concrete slab with living space underneath. I've read that a 6 mil vapor barrier should be glued to the concrete, 3/4 inch plywood with 4 screws through into the concrete, and the wood floor nailed/stapled to the plywood. Would you agree? Is there something 'better' than 3/4 plywood as an underlayment for what I hope to walk on for the next 60 years? The rest of the floor will be nailed on 3/4 x 5 1/2 t&g subfloor, unless you can convince me to do it differently.
mason is offline   Reply With Quote
Tags
teak floor concrete
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
