Old 12-20-2010, 09:49 PM   #1
new solid maple floor noise
just got new solid maple flooring done in newly purchased old home. plywood drilled into concrete foundation and maple nailed in on top of plywood. but the new floor squeeks, some spots more than others. this normal?
homehomehome is offline   Reply With Quote
Old 12-20-2010, 09:56 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Turn up the stereo....
Plywood on concrete is a bad, bad bad, did I say bad idea?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 12-21-2010, 12:38 AM   #3
funny, not really.
but thanks for the info
Old 12-21-2010, 11:30 AM   #4
Civil Engineer
Squeaking floors are always caused by differential movement of the hardwood over the substrate. This can be caused by a variety of factors, including inadequate support, improper installation of the substrate, improper installation of the hardwood, differential moisture conditions between the bottom and top of the wood, and a few less common problems.
As noted, installation of hardwood over concrete is problematic because the concrete tends to wick moisture upwards, creating a condition where the bottom of the hardwood is at a higher moisture content than the bottom of the hardwood, causing the potential for warping of the hardwood. The same issues can cause problems with the substrate, especially if the wrong type of plywood was used.
Since you seem to indicate that the floor was newly installed, I suggest you discuss this issue with the installer. Ask to see their moisture test on the concrete, and determine exactly what steps they took to control moisture wicking through the concrete.
Old 12-21-2010, 12:54 PM   #5
thx, will do that.
Solid Surface vs Granite and Quartz jbeall General Discussion 26 03-15-2011 04:49 PM
Nailing solid maple crown problems!! help!! zetti1102 Carpentry 16 11-30-2010 10:41 AM
Solid Maple Flooring over OSB Ron6519 Remodeling 10 08-27-2009 12:52 AM
Maple..confused. Need Help!!!! SciFi2009 Flooring 2 12-25-2008 06:45 PM
Building a Cabin on Solid Rock thatstaken2 Building & Construction 1 08-11-2008 09:28 PM
