New Oak Finishing - Flooring - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 01:01 PM   #1
New Oak Finishing
Hello all, great forum here as this is my first post. I've installed the second and third rooms of red oak and I'm rethinking my process I used on the first. On the first I used a hand orbital sander to prep the floor and it seemed to work fine although time consuming. I don't want to do that again with two floors to do. I used MinWax Super Fast Drying Poly and the first coat was fine but the second seemed to drag and pull some fibers from the lamb skin applicator. In between coats I sanded with 220 like MinWax said. Not sure if the grain raised too much and I needed a higher grit. I don't want that to happen again and I'm now trying to be sure of my process now. So, I'm thinking of a rental orbital sander for the initial sand but I'm not sure if I'll need it between coats. I don't want a drum sander as I'm not into that experiment at this stage. Any advice would be great.
Thanks in advance.
Erik
ekkoville is offline   Reply With Quote
Length of finishing nail for baseboards djgrant Carpentry 6 06-06-2011 08:01 PM
Normal level of finishing new drywall? MikeKy55 Drywall & Plaster 23 05-21-2011 03:42 PM
Resilient Channels and finishing drywall 9728 Building & Construction 5 06-08-2007 08:32 AM
drywall finishing BOP101 Building & Construction 3 10-07-2006 08:31 PM
Finishing nail removal bklauer Carpentry 6 09-05-2006 07:13 AM
