Old 08-28-2012, 02:11 PM   #1
New New Homeowner - Laying Pre adhesive Tiles
Hello-
New to the forum as well as home ownership. Been doing alot of work on the house (replacing floors, appliances, changing fixtures, painting, staining, etc).
Looking to get a little more indepth, the next projext is to lay pre adhesive tile in the laundry room. Its a temporary permanent solution until I save up money to completly renovate kitchen/laundry room.
I have completly cleaned the concrete floor with Zep Cleaning Product. The floor is fairly flat, not perfect but ok. Do I need to either apply leveling compound and/or a sealer? If so which and what brands?
Any tips/advice are appreciated.
phillysfinest4 is offline   Reply With Quote
Old 08-28-2012, 03:14 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Pre-adhesive? Do you mean 'peel & stick"?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 08-28-2012, 05:11 PM   #3
Not going to find many peel and stick fans here. It's the lowest of the low grade flooring products.
Very hard to install and keep a straight line because it trys to stick so fast and there's no adjustment.
I will show every flaw if the is any under it.
I tends to shrink and gaps open up.
Over time some pieces will come loose.
If it's temperary they have linolium sheet flooring that does not need to be glued down.
One piece flooring is a good idea in a laundryroom to help prevent water damage.
Old 08-28-2012, 09:11 PM   #4
Thanks guys. Its definetly temporary. I unfortunately already bought the tires and do.not have the receipt anymore to return. The only people who would see the room would've my wife and I. Can they just stick directly onto the concrete?
Old 08-28-2012, 09:27 PM   #5
You can stick them directly to the concrete, but it needs to be perfectly clean.
Old 08-28-2012, 09:32 PM   #6
Cool, thank you. Can't say I wont have more questions in that and future but this is good for now.
Laying Slate Tiles on Concete Patio langstraat Concrete, Stone & Masonry 1 05-13-2012 05:23 PM
Self adhesive vinyl tiles on new (un sealed) concrete? danster44 Flooring 15 03-19-2012 03:57 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 05:58 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
calking backer board to tub glassman General Discussion 13 06-19-2008 09:41 PM
