New Kitchen Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 08:37 PM   #1
How do I build up tile for my new kitchen floor
The old kitchen vinyl floor was torn out as well as the 3/4in subfloor, still leaving the 3/4in plywood on the joists. This plywood was very loose(loose nails) so all edges were screwed into the joists. we want to tile the floor now to match the 3/4in hardwood floors which surround the kitchen in the adjoining rooms. What should we use as an underlayment,(plywood or cement board) and in what thickness if we want to install a 1/4 in tile? Also would it be good idea to install DITRA? If so then what thickness to build up to height needed and what underlayment is recommended then? DITRA states it is 1/8in thick. Thank you
jiily is offline   Reply With Quote
Tags
building up a subfloor , ditra , tiling , underlayment
kitchen floor advice Grumpy Flooring 4 03-21-2011 04:34 AM
linoleum floor for new kitchen evey Flooring 1 03-04-2011 04:43 PM
Sagging floor in kitchen...Advise please MGK01 Flooring 3 02-25-2011 12:34 PM
Rookie DIY'er: Kitchen Floor Project Gpike Flooring 2 02-25-2011 12:30 PM
