New Home With Laminate Floor From Armstrong - Flooring - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 03:27 PM   #1
DYJ
New Home with laminate floor from Armstrong
Our new home upgraded with Armstrong Grand Illusions laminate floors. It looks great. However, when we walk on it, it squeaks and creaks both upstairs and downstairs. The floor installer and Armstrong distributor said this is normal due to laminate floor. The house builder said they can not do anything since we selected laminate floor. Can anyone help us how we should do to fix squeaky/creaking floor with the builder or Armstrong.
Thanks!
DYJ is offline   Reply With Quote
Old 07-06-2011, 03:35 PM   #2
Rewards Points: 1,016
The floor should not squeaking. Saying it's laminate and this it does this is just not right. Builder likley needs to fix the subfloor. Are the floors floating, glued, or nailed?
____________
Vince
Old 07-06-2011, 04:03 PM   #3
DYJ
The floor is floating. By reading over other discussion, it seems the laminate floor may have creaking if the joints are not manufactured accurately. Armstrong Grand Illusions was made in China. Do you think this may be the issue. Since the floor installer said the subfloor is leveled and underlayment was installed.
Old 07-07-2011, 05:53 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
We've seen a lot of similar issues with this product. The Grand Illusions has drop together end joints with no locking system on them. Only the long edges lock. The short ends move more and tend to creak.
Darkling Designs
poppameth is offline   Reply With Quote
Old 07-07-2011, 07:53 AM   #5
DYJ
Thank you. Is there any way to fix the squeaky/creaking problem.
Old 07-08-2011, 05:46 PM   #6
DYJ
We found more info on the planks of the Armstrong Grand Illusions. The floor material is made in China. Someone else may bought the same lot. The label on the plank is Armstrong L3030 12 S LESH 1 Run Date 04/21/2011 Made in China 20:10 B. Does anyone know how to fix the squeaky/creaking while walking on.
Thanks!
David
Old 07-09-2011, 10:45 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
The only way I know of the really fix it is to take the floor apart and reinstall it while gluing the end joints. The sad thing is, other companies have chosen to use this method as well and for the most part I haven't seen any problem with them. Maybe quality control on the Armstrong stuff is lacking and too much play is allowed in their joint.
Darkling Designs
Old 07-11-2011, 01:52 PM   #8
Armstrong's Response to Laminate Noise Issue
Hi! We apologize for the difficulties you are experiencing with your Armstrong floor. There are various reasons for excessive noise in laminate flooring to occur. Please contact our customer service department at 1-800-233-3823. They will be able to review some possible causes of this issue with you and help you determine the next step to take.
Kim with Armstrong Flooring
Armstrong Floor is offline   Reply With Quote
Old 11-02-2011, 07:35 PM   #9
Armstrong Grand Illusions Creaky Floor
My Armstrong Grand Illusions flooring snaps and pops, too. My 1/4-round molding around the perimeter of the floor may not allow the floating floor to shift enough but I doubt if molding tightness is the root cause. Another problem is the musty smell emanating from this product. As soon as I walk in the door after being outside I can smell this musty odor. I'm certain it's the flooring and nothing else. There are other posts regarding the smell. I've lived with this flooring for over 2 years and am not happy whatsoever with this product.
Grimeyguy is offline   Reply With Quote
Old 11-03-2011, 08:46 AM   #10
Armstrong's Response to Grand Illusions Comment
We are sorry to hear that you're unhappy with the performance of your floor. Armstrong does have a process in place to handle these sorts of issues with our floors. The process works through the retailer where the floor was purchased. Please contact your retailer and arrange for them to inspect your floor. If for some reason you are unable to contact the retailer, please contact us directly at wecare@armstrong.com.
Old 11-03-2011, 09:27 AM   #11
mrs fix it's Avatar
Interesting that Armstrong Watches these forums, it must mean that they have enough complaints that know where to look.
mrs fix it is offline   Reply With Quote
Old 11-03-2011, 09:34 AM   #12
I did some additional tests with spare Grand Illusions planks and can say the product does indeed smell and was made in China. There are 2 different dates of manufacture, April 2009 and February 2010, on the spare blanks. The tough finished floor mylar coating seals the smell, it's the particle board joints and end cuts that smell. I've had so many issues with this product! The first problem was proper levelness where no more than 1/8" deviation every 6' was not met by the flooring contractor. In fact, no subfloor levelness preparation was done whatsoever. Levelness issues were addressed but not done entirely correct. There were a couple of high spots we opted not to grind down due to dust and instead attempted to float out. Support from Armstrong, the builder and the installer has been middling at best.
Old 11-03-2011, 11:11 AM   #13
Sephora's Avatar
Rewards Points: 150
This was my thought too...strange that someone makes an apperance after a complaint is done.
I belong to a BMW forum and same thing there....BMWUSA will magically appear when someone is ripping mad.
Sephora is offline   Reply With Quote
Old 11-03-2011, 11:38 AM   #14
Armstrong Follow-Up
We do apologize for your troubles and sincerely want to offer our assistance. In order for us to be able to help, we do need more information. Please contact Armstrong direct at wecare@armstrong.com. A customer service specialist is awaiting your email and does look forward to providing you assistance.
Old 11-03-2011, 11:52 AM   #15
Armstrong Customer Service
At Armstrong, we sincerely want our customers to be satisfied with our flooring products. Our well-trained customer service relations team is available to take any calls related to our products - from questions related to finding a floor, to DIY issues, to floor care to warranties and more - Monday thru Friday, 9-4:30 EST. (1-800-233-3823) or by email at wecare@armstrong.com.
Armstrong Grand Illusions Laminate? wheatiesb1 Flooring 34 01-23-2013 04:06 PM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 05:05 PM
Need home plans for a simple barn home! RUMBLON General DIY Discussions 0 06-02-2011 03:05 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
