New Hardwood Over Old Pine - Flooring - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 04:49 PM   #1
Rewards Points: 12
New Hardwood over Old Pine
I own a 120 yr old row house. The bedroom floors are the original 3/4" x 2 1/2" pine directly attached to joists. The floor has been sanded and refinished twice. They are in bad shape (big gaps, splintering) and cannot be reasonably refinished again and the new flooring is already purchased.
I plan to lay new 3/4" oak hardwood flooring. What do I need for underlayment? Can I just lay the new floor perpendicular to the existing floor and parallel to the joists? Or should I support it with 3.8" plywood or OSB? Or should I just lay it diagonally?
Many Thanks,
SPL
Soparklion is offline   Reply With Quote
Old 04-28-2012, 11:26 PM   #2
Rewards Points: 81
How much clearance do you have the doors? Will you be able to fit the options you listed?
Total Tool is offline   Reply With Quote
Old 04-28-2012, 11:30 PM   #3
Rewards Points: 12,878
Going to also have a vaper barrier.
Old 04-29-2012, 03:40 AM   #4
You should be just fine going perpendicular to the existing floors.
RhodesHardwood is offline   Reply With Quote
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 06:50 PM
hardwood over old pine floors nwhitehurst Flooring 4 03-13-2011 11:06 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
