New Hardwood Floors = Strange Natural Gas Odor - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-26-2009, 09:27 AM   #16
We just stained and applied polyurethane to bookshelves that we built into our basement. Since we applied the polyurethane, I smell the gas odor, similar to natural gas when ever I use the stove or the dryer. Guess we just need to wait for it to dry.
bonsaidi is offline   Reply With Quote
Old 12-16-2009, 08:12 PM   #17
Exclamation
The fumes that are in the air from your stain/varnish/paint - yes, even latex paint are chemically reacting with the heat source - giving the whole NEW charcoal lighter smell.
We just had a technician from MidAmerican Energy here - for the same reason. Years of refinishing wood projects and one day I touch up some trim in the house.... The tech said that the petroleum based substance is the culprit - and he said there have been crazy experiences involving a dog flea dip causing the odor - and even various latext paints.
A bit embarrassing, but better safe than sorry. The tech also said that the NEW odor is TOXIC and air out the room. You may not smell this with a furnace or water heater because those are vented to the outside.
He said the odor will stop once the product has cured, not just dried.
qchawkfan is offline   Reply With Quote
Old 03-17-2010, 10:01 PM   #18
Like everyone else, we had new hardwood floors installed and finished in our home. After the coats of polyurethane on the kitchen, dining room and foyer floors, the kerosene smell was prevalent in our dryer, AND our refridgerator/freezer and IT'S STILL THERE. The last coat was applied on 3/15/10 and we can't use our dryer and the food and ice in the freezer have the same strong smell. Is the food in the freezer still good or do we throw it out? How long do we have to wait? Do we need a new refridgerator/freezer and dryer? Tried placing charcoal in the dryer and baking soda in the fridge and freezer. No success yet. Are there no solutions to this problem and if not, why aren't we told of this BEFORE the work begins?
jjoliver is offline   Reply With Quote
Old 10-26-2010, 04:54 PM   #19
I'm late to the party but I also have the same issue, although I'd describe the smell as "hot dryer" and the cause is either stained/varnished woodwork or painted concrete, rather than wood flooring.
My problem is that is has been a number of weeks since any painting, staining or varnishing has been done and the smell is still overpowering when I use the dryer or gas range...the dryer is especially strong. To verify this problem, it was suggested by someone with the gas company that I light some candles to see if the problem existed, without use of the dryer or stove. The problem did exist, but it was not as strong as either the stove or dryer.
It's getting cold here and leaving windows open is not a feasible option. Other than waiting for the problem to subside, does anyone have any other suggestions?
Any help would be greatly appreciated since this has now been going on for more than a month.
nflmvp is offline   Reply With Quote
Old 10-26-2010, 06:10 PM   #20
gas smell
I know exactly what you're going through. Fortunately, for us we had our floors replaced in the summer. Windows and time were our best friends!!! We put charcoal on a tray in our dryer and our stove. Other than that, time was what all it took. It's the poly-coating on the floors and it just needs time to cure. Sadly, nobody tells you this in the beginning and it's quite a surprise. Took us almost a month!! Good luck!!!
Old 12-04-2014, 09:01 AM   #21
Rewards Points: 6
I thought that my gas dryer had gone loco....or maybe it was me!When I opened the door to get the clothes out of the dryer, a horrid smell of kerosene was coming off the clothes!!! Scared to turn it back on, thinking the house may blow up...instantly started trolling Google, and found that everything that you all are posting must be correct! My question is, we are remodeling the basement (Where the Gas Dryer is) and we are polyurethaning the concrete floors. How long is this smell going to last??? I am going to have to take the clothes to the laundry mat to dry them, because the smell is horrible!!!
leowilson is offline   Reply With Quote
Old 12-04-2014, 09:16 AM   #22
Doc Sheldon's Avatar
Rewards Points: 400
Hi, Leo. Reading through the thread, it seems like it's taking up to around a month for some of the others. Of course, that'll vary by the amount of work you did, your temp/humidity and the amount of air circulation you have in your home.
Doc Sheldon is offline   Reply With Quote
The Following User Says Thank You to Doc Sheldon For This Useful Post:
leowilson (12-04-2014)
Old 12-04-2014, 09:34 AM   #23
Rewards Points: 6
Do you know what the temp/humidity should be? It is around 40 degrees where I am, and not really able to open windows....although I would and wear coats if it will help with the smell LOL, The laundry room is 14X9, and the room we are currently working in. I wondered if I hurry up and finish this room, close the doors after it cures when I am working on the rest of the basement if this will help?
Old 12-04-2014, 10:18 AM   #24
Rewards Points: 400
At this point, Leo, I'm going to step back and let someone that specializes in treatments respond... not my area of expertise.
Old 12-04-2014, 10:22 AM   #25
Rewards Points: 6
Thank you for your honesty!!!!!
Old 12-04-2014, 05:05 PM   #26
Rewards Points: 366
If one has a gas appliance with a pilot light, and one uses solvent based urethane or oil based paint or many different flooring products, one will get that weird smell. It is not dangerous...and does go away...but the time involved dends on your individual circumstances such as product used, amount, weather, tightness of house, and many others. Ron
ront02769 is offline   Reply With Quote
where to get 1/4" thick hardwood floors? dozu Flooring 3 04-30-2011 05:17 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
New Hardwood Floors art2670 Flooring 2 12-05-2007 01:34 PM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 03:34 PM
polyurethane coat for hardwood floors. christy123 Flooring 2 12-10-2006 10:20 PM
