New Grout Problem - Flooring - DIY Chatroom Home Improvement Forum
Old 09-07-2008, 05:21 PM   #1
New grout problem
I am having a bathroom remodeled. The tile was grouted on Fri. and Saturday the drywall guys came in and did not cover the floor or tub surround. They got drywall mud all over the grout and when it was wiped off, my grout is now almost white not the nice light brown that it is supposed to be. Help! Anyone have any suggestions? If they tell me they can regrout all this, will it hold as well as the original grout? I have never had tile before so not sure what to expect as recourse here. The whole ordeal has made me sick!
Jorja
GeorgiaGail is offline   Reply With Quote
Old 09-07-2008, 05:33 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
May be able to scrub it and rinse it and scrub it and rinse it and scrub........
It may or may not clean up. Is it sanded grout? I assume it hadn't yet been sealed? How about it, would you get any joy out of watching the drywall guys crawl around on their hands and knees cleaning your floor?
All that can be done at this point is an earnest attempt to clean it.
Old 09-07-2008, 05:43 PM   #3
Thanks for your suggestion. I have no clue what kind of grout was used. And it had not been sealed. It was just grout on Friday. It looked so nice!
I took a brush and water and worked on a small area. I will see if that works. Will try it several times and see what happens.
If it comes down to regrouting, will it hold up as well as the original grout? My fear is that it will not hold and will crack and start falling out. The tile guy already told me when they do the grout on the other bathroom that he could regrout the floor. But then the surround was affected too. That is going to be a lot of re-grouting.
Georgia
Old 09-07-2008, 08:56 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
Who's in charge of scheduling the work there? Why was there drywall sanding going on after the tile work was already done? The person that scheduled the work need to start scrubbing.
Jaz
Old 09-07-2008, 10:22 PM   #5
Registered User
Termite's Avatar
You can always re-grout without any real strength issues. The challenge is removing the old (actually new in this case) grout to facilitate installation of new grout. Removing grout is a chore.
I'd get that drywall guy a scrub brush, knee pads, and a bucket of water. Otherwise we'd be in small claims court if he elected to not protect the floors.
As stated, this is a very improper work flow on a project!
Old 09-08-2008, 07:21 AM   #6
Whatamess
I would let him get his own knee pad ,bucket and brush
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-09-2008, 02:44 AM   #7
Georgia,
Calm down, no re-grouting should be necessary. As a cleaning professional I have come across quite a few of these situations. If you have not already corrected the problem, you can do a couple of things. Hire a professional, which I recommend (at the dry-wallers expense), or use a steamer and a shop vac. You really don't need the heat from the steamer, you are just looking to "blast" the dry wall dust out of the grout, then suck up with a shop vac. You can get decent results using just water with a brush and vac. Do not go crazy with a bunch of chemicals trying to get it out, water is all that is needed along with the right process.
If you decide to hire a pro, just do a search on Google for "tile cleaning", followed by your city. Look for a cleaner who uses a high pressure method, usually with a truckmount. A pro can blast that dust out of the grout in a matter of minutes.
az
azclean is offline   Reply With Quote
Grout color rubs off lmlark Flooring 12 07-17-2013 06:55 PM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 09:51 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
grout problem farrington135 Building & Construction 3 10-17-2005 05:30 PM
