New Floor/subfloor In Kitchen. Need Ideas - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2008, 07:54 AM   #1
New floor/subfloor in kitchen. Need ideas
I am remodeling my kitchen, and finally stripped some of the laminate(?) flooring off to reveal the hardwood underneath, only to find that it is in pretty bad shape in some areas. My house has hardwood floors, and NO SUBFLOOR.
What would you do with this room? My thoughts were to remove the hardwood flooring, install 3/4"(thick enough?) plywood, then put cement backer down, and then ceramic tile. What do you guys think about this?
ALSO, I have a breakfast nook adjacent to this room that I also need ideas for. It currently has two layers on vinyl tiles on it, that were not coming up very easily. I have a couple of ideas here
1) remove the tiles + hardwood/subfloor, and do the same as in the kitchen(plywood, backerboard, tile). This seems kind of like overkill since the hardwood floors are in good shape here
2) remove the tiles + refinish the hardwood. The hardwood was nice under those floors w/ cool inlays and what not. I just don't know how well it will clean up. Plus, if asbestos glue was used to hold the tiles down, I would rather not go sanding that up.
3) remove the tiles + keep the hardwood + install cement backer over this and tile. Though this might be uneven w/ the kitchen because the hardwood is probably an inch thick.
what would you guys do?
Attached are some pics
Kitchen rotted
More bad Kitchen
more kitchen
one more kitchen
breakfast nook
trying to strip breakfast nook
kitchen meets breakfast nook
DanBress is offline   Reply With Quote
Old 01-22-2008, 07:21 PM   #2
What are the dimensions of the kitchen?
Are any floor joists damaged below the rotted floor?
redline is offline   Reply With Quote
Old 01-22-2008, 09:15 PM   #3
the kitchen is 87" x 120"
the breakfast nook is 80" x 146"
the floor joists all look like they are in good shape.
Old 10-20-2008, 08:31 PM   #4
floor
If you do add tile, put radiant heat underneath. You'll love it!
Allison1888 is offline   Reply With Quote
I need ideas and help with remodeling my 1922 kitchen TheSiege Remodeling 5 09-10-2007 12:15 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
