New Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 09:31 AM   #1
new floor
o.k here goes ,i have a room that is a add to my house ,but the floor is concrete with carpet just layed over it . i want to pull the carpet up and put down some type of plywood then some type of tile down and turn the room into a very large bed room. and advise would be very helpful and thanks
aljo159 is offline   Reply With Quote
Old 04-04-2009, 11:02 AM   #2
Remodeling Contractor
you do not need plywood over the concrete for tile installations. You will need to get all the glue removed and I would suggest using a waterproofing and isolation membrane like Ditra to install the tile.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
