New Engineered Hardwood Bowing? - Flooring - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-31-2013, 10:54 AM   #46
Rewards Points: 93
Originally Posted by MTN REMODEL LLC View Post
777... Thanks for the update to date.... I am watching the thread as my daughter has the same issue.
I assume they were just going to float your new floor over the cork underlayment.
Love to know what final solution you may discover
Best
Peter
Yeah, floating under cork. Not what I wanted to get done.
7 VII 7 is offline   Reply With Quote
Old 07-19-2013, 10:04 AM   #47
Rewards Points: 93
UPDATE:
After doing some more research and a RH % test of the concrete slab, came back at 85 to 87% RH. High from what I understand. Found a heavy duty product much better than a 6mil poly called VersaShield.
I am going to have a company lay the VersaShield, tape it, then lay a 1/8th cork underlayment and tape it then lay the Mirage Lock. The perm rating for VersaShield is 0.09 which is really low and should solve my moisture issue. The cork will act as a pad and allow the ground to breathe underneath the wood. Seems like my best option. I did not want ANOTHER moisture barrier below the wood which could cause mold.
Old 07-19-2013, 11:18 AM   #48
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,846
777....Thank Ya for the update...
I guess just a real good perm shield, is your only option over that moist a slab....
I guess you don't have to worry about moisture collection between the slab and Versa shield.... I don't know...just learning...
Good going.... Guess it would be fun to have a floor again
Best
Peter
MTN REMODEL LLC is online now   Reply With Quote
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 06:32 PM
From Carpet to Engineered Hardwood in a Weekend MisterPG Project Showcase 14 02-23-2011 01:48 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 08:45 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
