New Carpet Over 30 Year Old Pad - Flooring - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 03:16 PM   #1
new carpet over 30 year old pad
Hi, we removed 30 year old carpet from my mom's house. the pad is stuck to the hardwood floors, which we don't care about saving as she had animals over the years and what floor you can see is damaged. We want to have new carpet and pad installed. Can we do this without removing the old pad which is paper thin but stuck to the floor. If it needs to b removed what is best way? and quickest. Thanks much
marinemommy is offline   Reply With Quote
Old 06-04-2009, 04:15 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
I'm assuming it's bubble rubber. It had a clay base and turned hard, flattened out and stuck to the floor. Yes, you can install over it, but if there is odor from the animals, you will still smell it.
Old 06-04-2009, 05:38 PM   #3
Thank you! Would there be an easy way to get the bubble rubber up, or how should we (easy or not)
Old 06-04-2009, 07:12 PM   #4
Rewards Points: 42
Only way to get it up is to scrape it. I have installed over it many times.
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 02:23 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 07:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
