A New Bamboo Floor Project - Flooring - DIY Chatroom Home Improvement Forum
Old 05-14-2008, 11:16 PM   #1
A new Bamboo floor project
All,
I am just finishing my first hardwood floor project, a Bamboo floor for a media room.
I am finishing at a doorway that enters the room at an angle (see attachment). I am not sure how to finish it off. Should the planks be at a 90 degree angle to the entry? If so, do I have to cut boards in wedges in order to follow the bend?
Any help would be greatly appreciated.
Gideon is offline   Reply With Quote
Old 05-16-2008, 07:08 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
IMHO, You really should continue laying the boards in the same direction that you've already established. Otherwise, you'll have a joint that is not locked to the rest of the floor, and in a very high traffic point at that. I would definately not start parallel to the door with another run of straight boards and try to fill in with triangles, if that's what you have in mind. That would be a squeaky nighmare, and a real challenge make tight joints.
Old 05-16-2008, 07:53 AM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
I agree with Maintenance 6. Keep the boards the same. Go get yourself a cheapo protractor to help with the upcoming angles. A small plastic one can be had for under $10. Get a piece of scrap wood and test your angles BEFORE you start cutting up the bamboo.
Good luck
Angus
angus242 is offline   Reply With Quote
Old 05-16-2008, 09:52 AM   #4
Thanks for the replies.
I was hoping for such an answer. I have the tools to router grooves and such, but thought OMG what a pain it would be tackle the triangles.
Much appreciated.
Old 05-16-2008, 11:46 AM   #5
A bevel gauge would be the ideal tool to lay out the angles you'll need to cut.
a few questions about bamboo flooring installation bostonmike Flooring 2 01-19-2008 08:06 PM
Laying 5/8" Bamboo Flooring kirkeric Flooring 7 08-13-2007 02:36 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 01:17 PM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-19-2007 11:11 PM
