New Bamboo Floor Cracking - Flooring - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 11:33 AM   #1
new bamboo floor cracking
We installed bamboo flooring 7 months ago and it is already cracking. Every room now has several boards cracked lengthwise. Did I do this by using a Shark steam cleaner? We are in a desert climate.
speterson is offline   Reply With Quote
Old 08-27-2010, 12:08 AM   #2
lack of humidity can cup and crack bamboo floors (less than 20% humidity).
Is there any other signs of damage to the strips that have cracked, swelling ,etc?
gjjr2001 is offline   Reply With Quote
Old 08-27-2010, 10:01 AM   #3
bamboo cracking
No other damage-just long, thin cracks from end to end of board.
Old 08-27-2010, 10:07 AM   #4
floor_whore
Send a message via Yahoo to Aaroncarpet
Humidity
You may be able to get a manufacturer representative out there, was this flooring recommended to you, did you read the entire manufacture spec before installation?
Aaroncarpet is offline   Reply With Quote
Old 08-27-2010, 10:12 AM   #5
bamboo cracking
It was recommended @ Lowe's. Acclimatized for 7 days in house prior to install and specs followed.
Old 08-27-2010, 10:15 AM   #6
floor_whore
Manufacturer
You need to go to lowes and have a manufacturer representative from where the bamboo was made come inspect the floor...they may replace it for you.....hide your steam cleaner
Old 08-27-2010, 10:46 AM   #7
Rewards Points: 558
Using a dehumidifier or humidifier to maintain relative humidity in the home at 30-50% will maintain the moisture level in the wood and help minimize cracks between the boards. Continued excessive humidity may cause swelling of the floor. Continued lack of humidity (below 20%) can cause shrinking of the planks and/or cracking of the bamboo strips.
epson is offline   Reply With Quote
Old 08-27-2010, 10:58 AM   #8
floor_whore
Epson is right
Epson is correct...but, you the consumer, was not warned of the downsides of your climate and the effect it would have on this style of laminate....
To use, or not to use Bamboo... dmcandy Flooring 10 08-23-2012 12:19 PM
Bamboo Flooring Installation - subfloor question Shazza Flooring 5 03-19-2011 01:34 PM
refinish bamboo? racebum Flooring 0 07-23-2010 03:08 AM
Solid strand woven bamboo in a basement? Seattle_Chris Flooring 1 05-17-2008 11:01 AM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 01:17 PM
