Old 08-23-2006, 01:23 PM   #1
Need some transition moulding advice...
Hello. I am going to install the Quick Step Elegance 8mm flooring next month and I'm trying to get the transition moulding detail worked out now. This flooring is 4" wide and comes in random lengths.
I need to transition from the kitchen tile to the flooring. The issue is there is almost a 1" height difference from top of the tile to the top of the subfloor. I planned to use reducer but the reducer verticle height is no where close. Any ideas?
Also, how would a pro transition around tile in front of a fireplace and sliding door?
Many thanks.
confused is offline   Reply With Quote
Old 08-23-2006, 04:46 PM   #2
They're all fixer-uppers
J187's Avatar
http://www.schluter.com/english/prod...02-reno-u.html
Maybe that is what you are looking for?
J187 is offline   Reply With Quote
Old 08-23-2006, 05:41 PM   #3
It might do for the Kitchen. Still not sure on the sliding door and fireplace tiles though...
Old 08-23-2006, 10:03 PM   #4
Middle aged floor guy
Donedat's Avatar
You could get some 3/4" wood to match your laminate, rip it down to 2" or so, rabit it so the laminate will slide under. Use this new material as a boarder around your fireplace. Oh, stain and finish it to match the color of your laminate.
Donedat is offline   Reply With Quote
Old 08-24-2006, 05:35 PM   #5
That's an idea, might try that.
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
Is it best to caulk new moulding edges before painting? Davo Painting 8 04-15-2007 12:12 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
Wood Interior On Patio Door with White Moulding tom_patriot Remodeling 3 12-06-2006 06:51 PM
