Need Some Real Help From A Real Forum:Ditra Question - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 05:30 PM   #16
Rewards Points: 152
Ditra Handbook (schluter.com) p. 24 (download as pdf) says 1/4" x 3/16" or 5/16 x 5/16, or Schluter-Ditra (11/64 x 11/64) trowel is fine.
lazzlazz is offline   Reply With Quote
Old 04-10-2010, 10:50 PM   #17
Rewards Points: 152
Originally Posted by JazMan View Post
Not sure what you read, but John has always said he could use a "well worn" 1/4x1/4 trowel for the job. In any case it's not rocket science, the process is fairly forgiving but you really should follow directions from the manufacturer.
Ditra is going to go down well regardless if you use too much thin set under it. Schulter doesn't want you to negate its uncoupling properties though. Applying too much thin set will tend to do just that.
Jaz
Can anyone explain why too much thinset under Ditra negates the uncoupling properties? Shouldn't it be set just as strongly in an appropriate amount of thinset as opposed to a little too much thinset? Thanks. I don't see why (I'm not saying I disagree, either) and am curious to know the answer.
Old 04-11-2010, 01:03 AM   #18
Tileguy
JazMan's Avatar
Rewards Points: 228
The idea is to bond the fleece backing not fill the cavities from the underside. Too much thin set can also create small humps, plus it's a waste. The correct way is the correct way. Applying more does NOT make it stronger. Have you seen the animation of Ditra's action? ........... Well, I can't find it now but the idea is that the fleece bonds to the floor and the rest of it goes where ever the stresses of the installation dictate. That how it works, it uncouples the subfloor from the tile work.
I have found the 5/16" V (roughly) works well, or the new Ditra trowel which I like. I thought the 1/4x3/16" V didn't leave enough mortar although Schluter still lists it as a recommended trowel. (I still don't see why).
Jaz
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
