Need Some Advice On Refinishing My Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 08:58 PM   #1
Need some advice on refinishing my hardwood floor
Hi everyone,
I want to refinish the hardwood flooring on my main floor myself and I have a few questions which i am not sure about.
The finish on my current (original) hardwood floor is peeling and flaky. I looked around and I believe an orbital sander with fine sand paper should be enough, and I wont need a drum sander. Is this recommended?
Also, my main concern is that i have two big couches that are very hard to move out to the garage as i have to take the front door, and i dont have anyone to help me, as its only my wife and I
I am wondering if i can do the flooring in section, so i can do one section and move the couches there, then do the other side. Would this cause any complications in the final finish? As in, will there be a noticeable difference between the 2 sections? If so, what is the best procedure to use to minimize/eliminate the difference between the two sections?
Thank you for the help.
EDIT: Also, would sanding the floor take away the grove between the floor planks?
twizller is offline   Reply With Quote
Refinishing hardwood floor with existing nail holes doglover55 Flooring 2 12-17-2010 09:47 PM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 07:53 PM
Expert advice..Hardwood floor finished with alcohol based product followed by oil bas mtrusso Flooring 0 01-10-2010 06:42 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
