Need Some Advice For Laminate - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 02:17 PM   #16
Rewards Points: 216
oh. i am going to bet that the taller boards are thicker. and will need to be replaced.
Fix'n it is offline   Reply With Quote
Old 03-24-2013, 07:19 PM   #17
Rewards Points: 1,046
I went to HD and took a look at the 1/4" underlayment. Well, it is actually very thin, and I'm not sure it will help or will do any good
The other plywood boards are of course much more expensive
Or another option would be to put some 1/2" OSB, cheaper?
Like I said, I have 2 boards with 1 edge not even with the adjacent one. There is something like 3 mm difference (yes, mm......I am french )
I took a closer look and it seems they are not T&G
So I could try to sand those edges and see how it goes
Or remove the taller board, but I am not "confident" doing that.....!!!
french_guy is offline   Reply With Quote
Old 03-24-2013, 07:42 PM   #18
Rewards Points: 216
you need to check just how "flat" that floor is. if you did sand just the edges to make them match, the rest of the board would be higher = not good.
do you want to do it right ? pull those boards up.
Old 03-24-2013, 07:42 PM   #19
Rewards Points: 216
btw. i have the SAME EXACT problem you have, to deal with.
Old 03-24-2013, 07:46 PM   #20
And what are you plans?
I really would like to put my laminate without having to do heavy (and pricey) additional work....!!!
Old 03-24-2013, 07:53 PM   #21
Rewards Points: 216
my plan is to replace the board. but i am not putting my laminate down for a good while. so i am not worried about it. i have just one board that is about 3mm too high.
what is holding your wood down ? screws, remove em. nails, pry bar.
Old 03-24-2013, 08:01 PM   #22
nails.......
Do you have an idea why some boards are taller? Did they "expend" for some reason?
1 more question: so you understood that my flooring is OSB....
Do I need a plywood underlayment anyway (other than to fix some flatness issues)?
Meaning if my current OSB flooring was perfectly flat and smooth, can I lay down laminate directly onto it (with the proper padding of course)
Old 03-24-2013, 08:17 PM   #23
Rewards Points: 216
Originally Posted by french_guy View Post
nails.......
idk. i figure that it is some kind of manufacturing defect. but, that doesn't matter = it is what it is, deal with it.
so is mine. and i plan to put the laminate right on top of it, with whatever "padding" i decide on.
did you check how flat the floor is ?
Old 03-24-2013, 08:19 PM   #24
Rewards Points: 216
oh. you don't want nails holding that down. they will eventually loosen and cause noises. BEFORE you put the laminate down = screw all those boards down, use a LOT of screws ! otherwise you are asking for a lesser quality result.
Old 03-24-2013, 08:20 PM   #25
No, I didn't check yet...
Hope it will be OK without any major low or high areas !!!
Old 03-24-2013, 08:30 PM   #26
Rewards Points: 216
well. just check it and report back. some out of flatness is ok, other out of flatness is BAD. depends
Old 03-24-2013, 09:16 PM   #27
oh yeah, I know....I did my family room in December, over a concrete slab
I had to do self leveling compound......
What is the regular thickness for an OSB floor:3/4" ? And what is the real thickness of a 3/4" OSB board?
I was thinking about my floor, and thought: what is the right board? The one thicker or the one that is thinner????
Old 03-24-2013, 09:19 PM   #28
Are you talking about the current OSB that I would need to secure with screws, or the new layer (plywood or OSB)?
Old 03-24-2013, 09:30 PM   #29
Rewards Points: 216
what is that osb on top of ?
mine is on 1x6 planks.
Old 03-25-2013, 06:45 AM   #30
This is the original flooring, and I assume that OSB is directly on the joists.....
So as far as I know, I only have 1 "layer"
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 10:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 07:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
