Need Some Advice For Fixing A Leaky Exterior Door - Flooring - DIY Chatroom Home Improvement Forum
Old 08-22-2009, 08:33 PM   #1
Need some advice for fixing a leaky exterior door
So after finding some water in the basement and spotting a bit of moldy, wet subfloor under my front door in two places, I decided I better find that leak. After much trial and error, I was finally able to locate where the water was coming in. It is coming in at both corners of the door. Here are some shots to help visually:
It is coming in where the grey strip stops and you can see the grooves. Is there something I can buy at the home improvement store to pop in there? Do I need to replace the entire grey strip? I am going to replace the entire door in the weeks to come as well as replace the moldy subfloor but until then, I need to get this water stopped. Any advice?
Thanks!
siuc1996 is offline   Reply With Quote
Old 08-22-2009, 10:04 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
And for answers to your issues about your leaky exterior door you go to the "flooring" department.
MODERATORS - MOVE THIS BUS.
XXX
Old 08-22-2009, 10:44 PM   #3
And yet I still can't find a door/window forum. *clueless, I guess*
Old 08-22-2009, 10:55 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just thought it would get more notice where carpenters hang out.
How about: Building & Construction
Carpentry
Remodeling
or even General Discussion?
Just some ideas.....
XXX
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 02:55 PM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 08:36 AM
