Need Opinion - Is This Baseboard Installed Properly? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 07:13 PM   #16
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
Had not looked at the bigger pictures. Just looks like drywall mud on them. They are plywood scraps from elsewhere. As bad a job as they did building the stairs, who knows why anything was done.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-01-2011, 07:20 PM   #17
Rewards Points: 14,026
Everytime I go back and look at the pictures I see something else wrong. The stairs on the right have the end grain of the wood trim sticking up.
The top piece across the stairs should have been run all the way across and the vertical piece should have ended below it so end grain would show.
Old 12-01-2011, 07:22 PM   #18
Rewards Points: 148
They certainly had no idea what they were doing.
Old 12-01-2011, 07:26 PM   #19
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
They need to run some bull-nose to wrap the carpet or trimanyways. It should hide.
titanoman is offline   Reply With Quote
Old 12-04-2011, 09:26 PM   #20
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What is the "setting bed"?
XXX
Old 12-05-2011, 10:16 AM   #21
DIY staff
Rewards Points: 7,174
Originally Posted by Bud Cline View Post
Bud--I think you added the wrong link---this one doesn't fit the situation---
Old 12-05-2011, 10:38 AM   #22
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
oh boy....
What's the finished floor going to be? 3/4" ?
The baseboard looks like it's spaced off the floor that much to allow for hardwood flooring to slip underneath?
I would have put my hardwood down first, then baseboard to it.
The baseboard coming down the stairs is 'busy'. If you like that look then okay.
Craftsman-wise....not okay.
Alternate method would have a sloped skirt board following the angle of the stairs. Not as busy as all those little pieces.
Observation...the rise of those steps doesn't look correct.
If the two floors are to be covered with the same thickness of floor (not same material) all the risers should be the same height.
2nd observation. I'd be concerned with the construction of the stairs also.
With the obvious miscut on that left stringer, they were struggling on how to do this.
Why would you leave a 1-1/2 " gap??? At least scab, screw and glue a filler piece.
http://i.imgur.com/McnBUl.jpg
Where were you when they cleaned up and said...."there.... that looks awesome"?.....
Have you paid them?
Is it too late to redo?
Set them down at your computer and let them read some of the comments about their "boatbuilding" skills.......
tcleve4911 is offline   Reply With Quote
Old 12-05-2011, 10:40 AM   #23
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Actually it is the correct link. I wanted to draw attention to the fact that these two threads are one-in-the-same. Not sure what the OP is up to 'cause this isn't making any sense. I don't understand why the tile installation in the one picture would be removed in return for the shabby and shoddy work the other pictures show being performed.
Maybe the OP could explain.
XXX
Old 12-05-2011, 12:39 PM   #24
DIY staff
Well--now I completely don't understand---This is beyond my grasp----I'll just go away and come if called-----
Old 12-05-2011, 12:40 PM   #25
Crusty Old Dude
Big Stud's Avatar
As a trim carpenter, I have been told to do just what you see here a few times. It is tough to do, especially when the treads are in place and you have to scribe around them. It is usually a result of poor planning and choices on the part of the designer or whoever is running the show. The one thing that the carpenter was guilty of was poor joinery as has been discussed already,
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 12-05-2011, 06:47 PM   #26
Hi Bud & everyone else that has been helping with this. Bud, here I'm asking about the baseboard installation; that's all. On the other thread I'm asking an entirely different question (setting bed). We had the travertine pulled and are replacing it with wood flooring. All I'm doing here (forum) is trying to find out, as you pointed out, if the work IS "shabby and shoddy". I didn't want to cross post and thought the two posts were unrelated.
Thanks!
a12733861 is offline   Reply With Quote
Old 12-05-2011, 07:14 PM   #27
kwikfishron's Avatar
Rewards Points: 832
Pretty ugly……….just the fact of them running the base before the wood floor screams red flags to me.
Those steps should be skirted, there should not be base there. It didn’t look to bad in the tile pic but it's WAY to busy now.
It does take both threads to get the whole picture.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
Bud Cline (12-05-2011), tcleve4911 (12-06-2011)
hot water baseboard flow question (long) fred54 HVAC 4 10-14-2011 03:39 AM
Install baseboard over/around existing trim of bathroom vanity? sunshine22 Remodeling 2 02-24-2011 08:39 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Baseboard Heat 80% Rule Question bltglt507 Electrical 1 11-06-2009 11:17 AM
Cast Iron Baseboard Installation Bob G. HVAC 7 09-15-2009 08:22 AM
