Need Kitchen Floor Advice Please - Flooring - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 06:12 AM   #1
Need kitchen floor advice please
We are in the process of doing our first home renovations in our first house which is including doing some sort of covering on the kitchen floor. The house was built in 1970 so has old wooden floor boardoards, we would like to tile but one tiler that we got a quote from said that tiling wouldn't work as the tiles would crack on these old boards within a couple years, another tiler told us we could if we use cement sheeting with a flexible good grade adhesive. We really need some advice on this as we are pensioners and can't afford to rreplace stuff after it is done Any help appreciated
belveder is offline   Reply With Quote
Old 05-21-2011, 06:19 AM   #2
Framing Contractor
Rewards Points: 112
Installing cement board under tile is generally the way it is done now a days. There are other membranes that can be used, but generally they are more expensive. A tile floor should never be laid directly over a wood floor, no matter how old or new the wood may be.
sixeightten is offline   Reply With Quote
Old 05-21-2011, 06:26 AM   #3
so even though our floorboards are old and squeak lol is it safe to lay tiles providing there is that cement board?
Old 05-21-2011, 06:31 AM   #4
Framing Contractor
Rewards Points: 112
Not necessarily. More screws could be added first to see if that resolves the squeaks. The floor joists underneath also need to be examined to determine if they can carry the extra weight of the tile. Find a tile guy that you trust and discuss these options with him.
Old 05-21-2011, 12:21 PM   #5
you will have to put a layer of plywood over the floorboards in order to tile. then 1/4 inch cement board over that with thinset under the cement boardand the cement board screwed to the plywood. here is a link to a deflection calculator. this will tell you if your joists will support a tile floor. you just fill in the info, unsupported length of the joists, height and hickness and spacing and type of wood if you can find it on the joist if you have access.most joists are stamped somewhere.
http://www.johnbridge.com/vbulletin/deflecto.pl
Old 05-21-2011, 08:52 PM   #6
thankyou for that, it's looking good for me
Old 05-21-2011, 09:56 PM   #7
Rewards Points: 252
I think you also need to consider how much flex your floors have. If they are very rigid, then plywood and cement board should work. But, I have a friend that had it installed that exact way and it cracked anyway. He ended up ripping it all out after several attempts.
Marty1Mc is offline   Reply With Quote
Old 05-22-2011, 12:05 AM   #8
the house was built in 1970 so I presume they wouldn't be very rigid
help! bring my kitchen together NewlywedKristin Interior Decorating 10 10-26-2011 02:08 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 08:59 AM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 03:39 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
