Need Ideas On Transitions - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 10:00 PM   #1
Dan
Rewards Points: 35
Need Ideas on transitions
I have three areas of transition that are tricky after a recent kitchen remodel. The first is from laminate to carpet, where the carpet was laid on ceramic tile (this was years ago), so it is higher than the laminate.
The next two are both carpet to tile transitions, again the carpet is on old ceramic tile and transitioning to new tile, lower than the carpet
I bought the 3 in 1 molding from pergo that includes a "step down" molding..I know tow of these do not even involve laminate, but could not think of anything else.
Tearing up the laminate or new tile is out of the question. I can trim laminate if needed. I can pull carpet up at the transition if needed and then tack it back down.
Would love some ideas, I have never dealt w/ transitions before.
dankoos is offline   Reply With Quote
Old 11-08-2012, 10:16 PM   #2
Rewards Points: 14,290
And transition is going to require getting rid of those metal trips.
Any real flooring store will stock or can order just about any style moulding you could ever need.
Here's just on example.
http://nelsonwatsonwoodtransitions.com/
Carpet over tile
How is it even held in place?
Old 11-08-2012, 10:26 PM   #3
Dan
Rewards Points: 35
Carpet over tile
I think he nailed the tack strip into the grout lines on the tile. We did that when we first moved in, had no time to pull old tile up (bought foreclosed house before old house was sold, baby on the way, etc), although hindsight is always 20/20. I do plan on removing the metal trip...was going to put normal tack strip down and use the step down molding. Will check out your link, thanks.
Old 11-09-2012, 02:26 PM   #4
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
When we went from tile to hardwood at my last house, there was over an inch difference between the floors. I got a 2x6 board and routed out under it so that it overlapped the tile and covered the edge. That created a threshold between the rooms and wasn't a jarring transition.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 11-09-2012, 02:35 PM   #5
Rewards Points: 3,816
I don't see a problem with any of them,just pull up the metal strip,and put in a flat transition on all of it.
Canarywood1 is offline   Reply With Quote
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 09:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 08:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 09:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 08:36 PM
