Need Help W/ Flooring! - Flooring - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 04:27 PM   #1
Question
Need Help w/ Flooring!
My boyfriend and I have been doing some improvements on our small house and we're looking to take up the tile in the kitchen. I want to replace the tile with slate tile and some crushed brick. Since I've never done this before, I'm interested in knowing what we should use over the grout to make the floor level and smooth. Any ideas? Thanks!!
cmercy is offline   Reply With Quote
Old 08-18-2013, 08:35 PM   #2
Rewards Points: 944
The crushed brick on the kitchen floor is a good idea.
I was at the Iowa state fair today and noticed some horses in the arena depositing manure and someone came out and just kicked some dirt over it.
You'll have the same situation. If you drop something on the floor, just grind it down into the brick chips and you won't notice it is there anymore.
You may have to replenish the floor from time to time as the brick chips move throughout the house and down the hvac vents, etc.
Other materials you might want to consider include 1/2" clean rock, straw, or wood chippings.
You might find it useful to install some thresholds in order to help keep the material in place. See the etymological background for threshold. This was used to hold the thresh (straw) in place, so it didn't go out of the house. The threshings must have been a great material to have on the dirt floor to keep dust down, give a refreshing smell, etc.
cleveman is offline   Reply With Quote
Old 08-20-2013, 08:31 PM   #3
Use a feather finish ardex patch. High psi strength, quick dry and easy to float.
Godspede619 is offline   Reply With Quote
Tags
tile; sealant
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-18-2012 11:51 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
